Question about Canon Cameras
IXUS 85 IS Lens error. Restart camera. Repeatedly. Tried taking battery out and replacing but same error.
SOURCE: canon ixus 900ti lens error
Canon ixus 900ti lens error
Posted on Feb 22, 2009
wipdhuls
  • 133 Answers
SOURCE: len error restart camera canon IXUS 80 IS
Its also known as E18 error and you would be surprised to see how this issue is resolved .. check the fallowing link:
http://www.e18error.com/posts/index.php
Posted on Apr 02, 2009
SOURCE: Lens error with Canon ixus 970 IS
Has anyone responded to you on this yet - I have had the same problem and don't know what to do?>
Posted on Apr 28, 2009
parjee
  • 83 Answers
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Posted on Sep 22, 2009
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Mar 20, 2010
When I turn the camera on "lense error, restart camera" occurs.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 30, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Lens unit is faulty is not zooming or working properly that why you getting lens error.
you can try to open camera and near lens unit you can blow with pump to remove any dust is not causing this problem if work then good other wise you need replace len unit
Jul 03, 2010 | Canon IXUS 80 IS Digital Camera
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
Lens error
yes, this happened to me, what you have to do is "snap" the lens back in place, if it is bent anyway. if it is not bent and it says lens error, does it the lens come in and out? if not then it is bent if so then there is a hardware error in the switch and you will have to send it to a profesionall. :) hope i could be some help :)
Jun 17, 2009 | Canon PowerShot SD770 IS / IXUS 85 Digital...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Dec 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error
try turning it on and when turning it off push the lens
Sep 09, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
343 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
