Question about RCA F32650 32" TV
Proper grounding point for RCA F32650 TV
How do I find the right grounding point for an RCA F32650 to discharge the tube?
I'm replacing the flyback and HOT.
  • 1,694 Answers
Re: Proper grounding point for RCA F32650 TV
Leave set unplugged for a few hours = HV gone or discharge to CRT ground strap........................
Note: Part list.....257805 or ASTI 2078 xformer and
237470 horiz output xistor ( Do not use generic)
transistor must be first quality, no seconds ! !
Posted on Dec 11, 2007
0 characters
3 Points
My rca tube tv has a high pitch whine when i plug it in no picture also
Hello you have a shorted Horizontal output transistor, also if you replace it also have the Flyback transfromer replaced also, these parts work in conjunction with each other, and if one goes bad its best to replace them both.
Dec 20, 2009 | RCA F32650 32" TV
Tv powers on but light just blinks and no picture or volume
A blinking power light would indicate a problem on the chassis board located inside the tv. Possibly a failed flyback or other electronic component. Its not cost effective to repair when you can invest in new tv for the same cost as repairing the defective tv. I should also mentioned the danger of dyi troubleshooting of the components inside the tv. I do not recommend unless you are familiar with properly discharging the tube to avoid electrical shock.
Jul 25, 2009 | RCA F32650 32" TV
RCA F32650 32" TV Problem:
The flyback is a a block with some wires coming from it. One of the wire is a big red wire that goes to the picture tube. The FBT is usually on the right rear of the circuit board.
Please be careful when working around the FBT as there are extremely high voltages present - in excess of 25K.
I would suggest you take it to a service shop as when the FBT goes, other parts are usually gone too.
Nov 03, 2008 | RCA F32650 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Adjust the two settings on the back of the flyback with a phillips screwdriver...
Dec 16, 2007 | RCA F32650 32" TV
Heres the fix for your set, replace the following 2 parts:
1) flyback transformer RCA part number 257805
2) horizontal output transistor RCA part number 237470
you must be proficient at soldering & un-soldering or you can`t replace these yourself, be advised that the anode lead coming from the top of the flyback transformer can carry a VERY NASTY shock if not discharged properly before trying to remove it from the picture tube, I`d strongly advise you to call a tech unless your familiar with this type of repair, BMW Rider
Dec 09, 2007 | RCA F32650 32" TV
Not turning on
Replace IHVT aka flyback xformer. part #257805 or ASti 2078.
Oct 05, 2007 | RCA F32650 32" TV
My RCA F32650 doesn't have a picture
Replace IHVT aka flyback xformer--part#257805 or Asti 2078.
Dec 29, 2006 | RCA F32650 32" TV
F32560 Rca Chirping
Replace IHVT aka flyback xformer part#257805 and horiz o/p xistor part # 237470.
Nov 30, 2006 | RCA F32650 32" TV
RCA F32650 32" TV Logo
121 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
