Free manual:
https://media3.bsh-group.com/Documents/9001217467_A.pdf
Contact Bosch to assist you:
https://www.bosch-home.com/contact-us
SOURCE: error code E 63
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food. If the message is either ERROR or E-6, it indicates a mechanical fault. For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This
is a problem in one of the damper-related components, most likely the
The
If the controller senses that the door is not in the right position, it
Sharp models stop after
59 seconds.
photo for a typical damper assembly.
Info on ordering Sharp
UK parts / spares is here.
We're
happy to help you with free advice and we'd appreciate your
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Error message E8 is shown in the clock display
Error Code:
E8
Cause:
Control Board
Example:
Remains in display; oven unusable
Corrective Action:
Replace control board
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
