Question about Audiovox AS9076 Car Upgrade Remote Start to Keyless Entry
I need to see if a add on remote start will work with my prestige
I have a prestige alarm with no modle number but i have a s/n 035180700048-01 I need to see if a as-9076 remote start will work with my system thank you james
    Scholar:
  • 55 Answers
The APS9076 is a OEM add-on remote start module only and not an alarm. Are you trying to add or find a remote to an existing Prestige alarm or installing one?
Posted on Aug 09, 2009
I have a 1994 Jeep Cherokee the prestige car alarm system the remote for the prestige alarm will not work so I cannot start the engine how am I able to start the engine without using the remote
your anti theft is activated,you need the original key and keyfob to start it,if you dont have them,all you can do is call a jeep dealer.
Apr 26, 2015 | 1994 Jeep Cherokee
Prestige car alarm remote not working
mostly self serve fixing them . id ask at a tint an alarm place
there is function to pair them again . have the remote tested if its putting out signal . point at a camera an watch . take it to autozone . listen to it on a radio close to it. you have 2 is the other working.
Jan 05, 2015 | Audiovox PRESTIGE APS920FACTORY...
I have an after market alarm the model number on it is 118c1123 -- other than that I do not know what it is called. Sometimes the car will not unlock when pressing the remote many times. It only does...
hi
first i would change the remote control battery's
if that works i would buy compatible remotes and reprogram via that working remote for a spare
i that didnt work
i would open the car via the key remove the cover under the dash below the steering wheel
there are normally 2 fuses to a car alarm remove the fuse on the red power led that will disable the alarm
but it will also disable the remote central locking
but you will b able to unlock the door with the key a start the car
aries
Oct 16, 2013 | Prestige Replacement Alarm Antenna...
I need to locate a SIM ID for the carlink App
you will have to go to a dealer that installs this type of car alarms and get an override code to be able to use your phone if button don't work.
Jan 28, 2013 | Audiovox Prestige Cl100 Carlink System
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
Oct 22, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
How do i program the remote start function on prestige 997
email me i cant help you,i need to know the model of the alarm and what kind of vehicle is installed here is my email reynosaelectronics@live.com.mx
Mar 13, 2009 | Prestige Remote Start
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Audiovox AS9076 Car Upgrade Remote Start to Keyless Entry Logo
285 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
