Question about Whirlpool Dryers
I just received my new dryer and I have a L2 code. Does this mean my electrical box needs replacing ????
    President:
  • 1,714 Answers
What make and model please>???
Posted on Aug 02, 2009
Can you get me a diagram on electrical hookup?
Hello;
My name is Peter. I am a retired field service technician.
I do not know if you have a 3 wire or 4 wire connection. For a 3 wire connection you need 15 AMPS at the breaker box. For a 4 wire connection you need 30 AMPS at the breaker box.
Three wire hookup. Center wire goes to N, the other two wires are hot. It makes not difference witch of these two wires go to L1 or L2. The ground goes to the cabinet.
Check the voltage - With a volt meter between L1 & N = 220V, L2 & N = 220V, L1 & L2 = 240. These readings are general. You may get something like 210V instead of 200V
Mar 10, 2015 | Dryers
How to connect the power to the dryer
most likely 240volts as most 120 volt dryers are already wired,depending on if its a 3 or 4 wire system depending on local electrical codes,but if its a 3 wire cord,take the RED to terminal L1 and Black to L2 terminal on the dryer terminal board HINT:(the RED and Black can go on either L1 or L2 they are interchangable) ,then the White wire to the N neutral terminal on the dryer terminal board usuall between the L1 and L2 terminal,if theres a Green Wire on the cord this is safety ground and can be attached to any metallic part on the dryer,if its a gray flat cord the 2 outside wires are L1 and L2 the center is Neutral,
so its:
RED=L1 or L2
BLACK=L1 or L2
WHITE=N or Neutral
GREEN=Safety Ground the metal dryer frame
Dec 09, 2012 | Dryers
Replaced control board on dryer still getting e61 code
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Nov 17, 2012 | Frigidaire Electric Dryer
I have an electric dryer with error code EA4. What does that mean?
An EA4 code can mean that the heating element is bad. (It's actually a time-out error; the unit did not begin to heat up in a timely fashion.) If you noticed the dryer getting hotter in those ten minutes, then the temperature sensor in the dryer may be faulty.
With the heating element, sometimes the element will have an obvious broken wire. The other diagnostic test is to use a volt meter and check for continuity in the wiring (resistance). Note: make sure the dryer is unplugged when you access the wiring.
I hope this helps.
Jul 29, 2012 | Frigidaire Electric Dryer
Brand new Frigidaire Electric Dryer gives Error E61. Store brought out another identical dryer with same result. Help please!
Note: You may need the service of a certified electrician for this task.
Jul 13, 2011 | Frigidaire Electric Dryer
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
What does ''L2'' stand for shown on Kenmore Elite Oasis st?
you can call sears parts service and they can tell you what code means
Aug 19, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Need to know how set the colors when replacing cord L1 N L2 grd?
I have change the outlet to a 120/240 and it worked after replacing the wire itself, thanks anyway
Jun 13, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer spins and blows out air, but no heat comes out. I had an old dryer before, and I replaced it with a fairly newer model and still, no heat is coming out of the dryer. I heard that it may be an...
Check connections at dryer terminal. sometimes they will melt and have now power and wont cause a breaker trip. plug needs 120v at L1 and 120 at L2 and equals 240 with L1 and L2 combined. can check at outlet with a meter.
Jun 08, 2009 | Maytag HYE3658AY Electric Dryer
Dryers Logo
133 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
