Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer only works when switched off and then on again. Paper is creased and ink smear occurs on left half
    President:
  • Canon Master
  • 1,447 Answers
You service your printer some of wast ink drop on print delevery area
Posted on Sep 06, 2009
My Hl 4070Dw laser color printer is makeing creases
Check that u have no paper stuck under the platen
get a blank sheet and feed it through manually
this will clear any blockages or residue one the rollers
if you still get a problem , the printer needs to be sent back to the manufactur
Nov 13, 2009 | Office Equipment & Supplies
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Ink smears on the paper
It could be the paper is not absorbing the ink properly. Try changing the paper/quality setting in printer properties.
Jan 16, 2009 | Brother MFC 7420 All-In-One Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
I have brought a replacement cartridge (black) for the Epson D92 stylus printer I folowed the usuel steps and sucsesfully printed 4 or 5 b&w pages now the printer does not seem to except the cartridge...
This may or may not work on your model
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
The Protection Counter referred to above prevents you from printing once the printed pages counter reaches a predetermined threshold.
If this doesn't work, let me know.
Regards,
Worldvet
Nov 11, 2008 | Office Equipment & Supplies
Print smear
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Oct 15, 2008 | HP LaserJet 1100 Printer
When I print from my computer to printer, the finish product is smeared and wet. On regular paper, it is fine. On photography paper is when it smears and is wet.
When you click on print, then click on properties, then click on basics. Then over on the left side you will see two sliders, the top one is ink consumption, if you will slide it to the left about half way, then click okay and click on paper and down at the bottom left you will see select paper and it will have automatic, click this open and select the exact paper you are using. Oh yes, you will have to do this every time you open the print window, it will always go back to default when you expit printing program.
Aug 04, 2008 | HP Office Equipment & Supplies
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
20 people viewed this question
old marine
old marine
