Question about Car Audio & Video
Idicator stalk on my vauxhall astra 1995
When indicating left all my front lights flick on and off this does not happen when i indicate right can you please help me?
  • dalemaxpower Apr 02, 2009
    iv been told its to say yr light out i unna try it does it go really fast
  • 709 Answers
You evidently realize this is not the right category to post a problem for your automobile. You probably have a cross in the wiring in your steering column. This is where the two circuits for your headlights and left turn signal come close togehter. Maybe your foot scrubbed against some wiring and caused the short. Good luck.
Posted on Nov 25, 2007
Front LHS park light and rear LHS blinker light remain on when ignition is off
Is the turn indicator stalk set to turn left? Some cars put parking lights on if it is parked up with the stalk in the left or right turn position and off when left in the mid or neutral position.
Apr 29, 2016 | Cars & Trucks
Remove indicator stalk on Vauxhall Vivaro
Remove steering wheel remove covers around switch check mounting bolts unplug switch loosen off securing bolt, lift off the column..
Nov 18, 2014 | Cars & Trucks
Reset service light on vauxhall meriva 2010
use menu on on indicator stalk to call up engine oil life this is sometimes indicated as a oil can [sorry forgot to mention ignition on ,engine not running] press set /clear button on end of indicator stalk and hold until it beeps [5 secs aprox]..this will reset it ,but it is normal for the warning light to stay on for afew days until it disappears ,the oil life should 100%.
Aug 28, 2012 | Vauxhall Cars & Trucks
Turn signal return
if you can use a screwdriver and find a repacement indicator stalk assembly you can fix it yourself ! sounds like the plastic flex return has broken off the indicator stalk (common problem ) remove plastic shroud from steering column. 2 screws will hold the indicator stalk in place remoove those & unplug the electrical connection- replace with new indicator stalk
Jun 01, 2010 | 1995 Buick LeSabre
I need instructions on how to fit the electrics to a vauxhall astra estate 2002 towbar,i have had to put other car make in boxes as it does not show astra estate
You can wire directly into the loom behind the left hand light unit.
The colours are L/H Indicator = Black White, R/H Indicator = Black/Green, Fog = Black/Blue, Brake = Black/Yellow, L/H Tail = Grey/Black, R/H Tail = Grey/Red, and Earth to be bolted to earth point here to.
Jul 04, 2009 | 2002 Volkswagen Eurovan
Vauxhall Astra Envoy indicators not flashing
With out doubt it is the Indicator Flash Unit (Found near fuses) its a plug type box. you pull it out, plug in new one and it works. (Kinda looks like a strange adaptor plug you would put in a power socket.
Jan 12, 2009 | 2004 GMC Envoy
Turning signals
hi if idicators when selected right or left turn ? do not blink but stay on? then this is the indicator relay(flasher unit) gone faulty located in fuse relay box? if you check h/book? it will give indication or look on underside of relay cover ?
Oct 07, 2008 | Hyundai Motor 1995 Accent
Vauxhall astra hazard lights perminantly on
hi there, just happen to read the problem with your hazard lights. but does the indicators work ptroperly? if not. i would suspect that indicator or hazard lights relay is blown . you can easily replace this diy stuff.. get the part from your local auto parts shop.
Dec 11, 2007 | Umax Astra 3400 Flatbed Scanner
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
