Question about Garden
My toro mower will start, but will shut off about 30 seconds later. it almost sounds like it is stuttering after i start it. after it is done sputtering, it shuts off
  • portlanduser May 02, 2014
    portlanduserI had the same problem and kept pulling the carborator out and filter, etc. I finally found the solution. Pull the cover off the mover. Look for the carborator. I used clamps to clamp off fuel lines. Remove craborator. On the bottom there is a small metal reservoir a little bigger than a golf ball. On the bottom of that reservoir is a brass hex headed "screw". Pull that screw out and look at it closely. There is a pin hole through the stem of the screw. Clean that out with compressed air or thin wire. I believe that is the fuel injector. Then put it back together and give it a try.
  • 74 Answers
Sounds like a Carburetor problem. The float may be sticking, or even bad gas or water in the fuel. Try some Starting fluid to see if it keeps running while spraying in the intake. Look at the smoke from the exhaust, if it is a dark color, then too much fuel and choking out, if it is a whitish smoke then it is starving for fuel.
Posted on Aug 03, 2009
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 | Toro Garden
Re my 2001 Toro Persal Pace Lawn Mower- The Engine Starts and only runs for 2-3 Seconds then shuts down. How to repair/ fix.
Could well be either you have low oil, or the oil pressure sensor is out. If it starts and sounds good then just quits this could be it.
Jun 14, 2011 | Garden
My lawn mower starts fine after i prime it but then shuts off aer 10 seconds
Sounds like it's starved for fuel. Usually this can be fixed by cleaning the carburetor and/or installing a carb kit. What are the model and type numbers stamped on the engine?
Oct 02, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro LX 500 Riding Mower with Kohler Courage 22 motor. I was cutting grass and it started hesitating and eventually shut off. It will start but only runs for a bout 30 sec to 1 min before it shuts...
When you had the fuel filter off, did gas flow freely from the hose? Sounds like maybe the tank has dirt in it blocking the fuel line. Other than that, maybe there is dirt in the carburetor bowl.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Toro Lawn Mower With Toro Power Tools
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
May 16, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn mover
If you mean that you prime the engine, it starts then dies a couple of seconds later, your carb needs to be cleaned/repaired.
May 24, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
187 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
