Question about Refrigerators
I have a GE Profile PFSS5NFWA bottom freezer/refrigerator. The door handle has separated from the bolt attaching it to the door. How do I get this fixed?
    President:
  • Refrigerators Master
  • 1,714 Answers
Unload all the stuff in the door shelf. Gently pull the door gasket from the door. Then you will be able to remove the plastic inner door. You will see the bolt for the handle at that poiint and you can back it up then to tighten the handle.
Watch the video for help...
Posted on Aug 02, 2009
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
GE Profile SS refrigerator Handle is off on one end.
the screw must have fallen out they are small allen screws that hold it on
Jun 11, 2010 | General Electric PFSS5NJXSS Stainless...
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
Apr 22, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE profile mirowave JVM1350WW002. Handle broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 10, 2009 | GE Profile Spacemaker Over-the-Range...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Nov 07, 2008 | GE Refrigerators
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
