Question about Sony PlayStation Portable (PSP) Console
Psp problem hi my psp will not read my discs but will read and play demo disccan you help please
  • 106 Answers
Re: psp problem
Do you have the casing on the umds? are theyc lean with no dents or anything
Posted on Nov 27, 2007
0 characters
3 Points
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
You need to send the psp in for service as the drive is malfunctioning. There is a problem with the lens of the disc drive when trying to read the discs.
Feb 27, 2011 | Video Game Consoles
Does nor read discs
the psp has certain conditions that needs to be met before it can read discs, for example, the region code of the disc must match that of your can check the region code on the pack of the disc you are trying to play and check the region code of your psp on the carton or better still, read the manual throuroughly to know the discs which are supported..hope this was helpful to you?
Oct 19, 2010 | Sony PSP (Piano Black)
Ps 3 doesnt read and play games
hi my sony PS3 playstation console won't load any games or read them; i ahve hardly played the console and only had it 10 months. PLEASE IF YOU HAVE ANY IDEAS TO FIX THE CONSOLE PLEASE ADVISE URGENTLY AS I DON'T KNOW WHAT TO DO; I AM STUCK!!
the console is from asia; a region free console
Pllease reply urgently
thanks nathan
Nov 08, 2008 | Sony Playstation 3 (PS3) Console
Psp will not play
It will not read the disc, because it is scratched or corrupted. If you try a new copy, it will be all set.
If this helps, please rate this solution as a FixYa. - Evolution
Jul 14, 2008 | Sony PlayStation Portable (PSP) Console
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Buy a UMD disk cleaner this may help
failing that make sure system plays other discs or that the disc you are trying to play, plays in another PSP.
If it plays other discs fine its not the PSP its the disc.
If it doesn't then its the PSP that will need to be sent away for repair.
Dec 15, 2007 | Sony PlayStation Portable (PSP) Console
Menu of the psp
Try a different disk? I've found that sometimes when you turn on the psp and you're in the game menu of the PSP menu, the UMD won't be there, but if you go over to music or something, and go back to game, it will have returned.
Aug 09, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
24 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
