Question about Optoma EP739 Multimedia Projector
I have an optoma ep745 projector. it starts up fine then after about 2 minutes it turns off and the lamp light comes on. I have purchased a replacement bulb and it causes the same condition.
  • scottyadj Aug 02, 2009
    The only issue is now that the projector thinks the lamp is bad, it wont light up long enough to get to the menu. Is there a way to reset the timer without any output?
    I cannot see the menu because the lamp will no longer light up. Once the power is pressed, the fan comes up with no lamp for about 10 seconds, then the lamp light will come on. I never get a chance to enter the menu to reset it. Is there a way to reset the timer without the lamp turning on?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. After replacing the lamp you also need to reset the lamp counter. From the main menu reset the lamp counter and after that restart the projector it will then work fine,
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 02, 2009
  • Rylee Smith
    Rylee Smith Aug 02, 2009
    Hi
    Have you tried to reset the lamp counter. From the main menu reset the lamp counter and after that restart the projector it should then work fine,
    Thanks
    Rylee
  • Rylee Smith
    Hi
    Unfortunately there is no other way to reset the timer. Please see the steps for replacing the lamp and check if you have replaced the lamp same way:
    1. Switch off the power to the projector by pressing the Power/Standby button.
    2. Allow the projector to cool down for at least 30 minutes.
    3. Disconnect the power cord.
    4. Use a screwdriver to remove the screws from the cover.
    5. Push up and remove the cover.
    6. Remove the 2 screws from the lamp module.
    7. Pull out the lamp module.
    To replace the lamp module, reverse the previous steps.
    Thanks
    Rylee
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
After a few minutes the projector turns off, the red light of the light bulb starts flicking
are you managing to get into the menu at all and reset filter and lamp hours?
By the way - although optoma what cheap option for our school, i now get hitachi with 3 year bulb warrenty.... mine BURNT out luckily not at weekend or school may have gone up too - expensive optoma really then if that had happened.
good luck
Jan 30, 2013 | Optoma DH1010 OEM Projector Lamp
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
I have an Optoma EP745 projector. I heard a 'pop'
check all the fans, if still working. if the problem occur get assist to the nearest technician im sure your lamp balasst was deffective.
Oct 22, 2009 | Optoma EP738 Multimedia Projector
Optoma DV10 projetor suddenly started made popping sound
hi,
Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
Rave services
Jan 12, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
May 02, 2008 | Optoma HD72 Multimedia Projector
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Optoma EP739 Multimedia Projector Logo
195 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
