Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire LEQ2152ES Electric dryer
Just purchased new 15 months ago. Each time we would start the dryer, an error 68 code would show. I called GE and they said button was stuck in, which was not. We tried all buttons - none stuck. It would continue to dry clothes, but continually beep. Even when we turned off, it would turn back on and beep. (very annoying at 2AM.) We unplugged then plugged back in, hoping to reset. Instead, now when you turn on, no error code, but drum not spinning - not working. Help!!!
  • 1 more comment
  • hjcook2 Feb 02, 2008
    I am having this SAME EXACT problem. Did you ever find out what it was?????
  • roseyates Oct 02, 2008
    I have same exact problem and have tried same solutions
  • Anonymous Oct 05, 2008
    I have the same problem does any one know how to fix it..... help me please.
I had the same problem. Frigidaire recommended swapping out the controller board, however I decided to try a few things first. What ended up working was to remove the controller board and cover it with Di-Electric Grease. When I removed the controller board there were a couple of small rust spots on a few of the solders points, that lead me to believe there was a moisture problem. By spreading the grease on the board it will repel any moisture. I did this a week ago and have had no beeping at all.
Note: Make sure you use a Di-Electric Grease, other types may conduct electricity which will short out your controller card. And don't forget to trip the circuit breaker and unplug the dryer before working on it.
Hope this helps.
Posted on Nov 30, 2008
  • 283 Answers
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Notice on dryer, a problem has been detected, call for repair. This dryer is forever doing this. Is there a way to try to reset the dryer? I just had it worked on about 8 months ago, put in a new...
Here is the instructions on how to but the machine into "service mode" so it will display error codes and we can take it from there. Post back with the error codes.
Jan 15, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a Frigidaire LEQ2152ES Electric Dryer. The light comes on when you open the door. And the lights and sounds come on when you push the settings. Push the start button, and you hear the tick for...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
545 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
