Question about Fox Interactive Motorhead for Windows
Window motor replacement 2002 ford expedition passenger
On the driver side passenger how to replace window motor
  • 454 Answers
Log itto autoze.com. they have free tech issues with pics and step by step which should answer your problem. have you checked the fuses? check to see if switch is seated and has clean contacts. this may be your problem......trying to help you save some money by not repeating my mistake...
Posted on Feb 11, 2010
2004 Ford Expedition. Power windows not functioning properly. Can use driver side window from driver switch, and passenger rear window( slow response) Other windows will not respond via either switch. Can...
Looking at wiring diagrams to see what all is involved in the power window electrical circuit's an using a DMM- digital multi-meter to test the B+ ( voltage ) side of the circuit and the negative (ground ) side is how a professional automotive technician does it. All power an ground goes through the driver's door master switch . Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click on body & accessories ,then under subsystem click on power windows . Click the search button then the blue link.
2003 2006 Ford Expedition Window Switch Replacement
2004 2008 Ford Power Window Repair
Ford Expedition Power Window Regulator Replacement
Nov 25, 2017 | 2000 Ford Expedition
Electric car windows will not close properly -every onr of them
POWER WINDOWS NOT WORKING & POWER WINDOW/REGULATOR ISSUES
It can be issue with motor itself. If it's not going up, then how its working down. But still it feels like weak window motor or is issue with power window switch. Get the voltage tested at switch and motor. Also try another working window motor at not working window side.
For more troubleshooting i suggest go through the help links mentioned below:-----
Its complete details with troubleshooting steps:------
Car windows will go down but come right back up
http://schematicsdiagram.blogspot.com/2011/06/car-windows-will-go-down-but-come-right.html
Power windows will not go up and relay clicks when switch is pressed?
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
How to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001 jeep grand cherokee Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power window motor on 2001 Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am power window not working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Auto open close feature not working for Toyota Avalon?
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
Lexus ES300 Power window out of time?
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
Rear power windows not working on Ford Mustang?
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
All power windows not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
2003 Chevy impala power windows not working?
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
All Power Windows Not Working
http://whatisbyme.blogspot.in/2012/07/all-power-windows-not-working.html
1977 Chevrolet Corvette Power Windows Not Working?
http://technoanswers.blogspot.in/2012/04/1977-chevrolet-corvette-power-windows.html
These details will help.
Thanks.
Dec 31, 2012 | Cars & Trucks
How do i change the drivers side window motor an an 05 kia sedona
You have to remove the inner door panel to
access the window regulator
You remove the regulator & then the motor from it
You Tube Video will provide a visual of several
similar window motor replacement jobs
Go there-- enter your car,question ,details,etc--- then move
around the site to watch various things
Dec 09, 2012 | 2005 Kia Sedona
Thank yo for the schematic Ernesto. It says Nissan 1996, so is the 2008 still using the same schematic?
It can be issue with motor itself.If its not going up,then how its working down.But still it feels like weak window motor or is issue with power window switch.Get the voltage tested at switch and motor.Also try another working window motor at not working window side.
==========For more troubleshooting i suggest go through the help links mentioned below:-----
--------------How to Remove Electric Window Motor on Acura Integra?
Laredo ?
These details will help.Thanks.
Nov 27, 2012 | 2007 Nissan Frontier SE Crew Cab
Low/no power to passenger window.
More than likely you have a bad switch. You can try to pry the switch apart and clean the contacts inside. Usually the passenger side switch is pretty inexpensive, around $25-$35. The switches get dirty inside from dirt or water dripping when it rains and the window is opened or if someone might have spilled something on it.
Oct 26, 2009 | 2003 Ford Expedition
Rear passenger window on my 2003 ford expedition
replace the window mechanism on that door
Oct 12, 2009 | 2003 Ford Expedition
Passenger window will not go up i think its
if the fuse was an issue then all the windows would be inop, not just one, the most common fault is the electric motor that runs the window up and down.
Oct 03, 2009 | 2003 Ford Expedition
Passenger side power window
it could be but lets start with the obvious
the switch
the fuse
burnt up wireing in side window
bad ground
Jun 10, 2008 | 1998 Ford Expedition
2004 Expedition Power Window problems and power seat
Hopefully by now you have resolved your problem but my truck had that problem and I had to replace the motor for the window controls.
May 25, 2008 | 2004 Ford Expedition
Fox Interactive Motorhead for Windows Logo
190 people viewed this question
Top Fox Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Fox Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
