Computers & Internet Logo
D
Doug Hull Posted on Aug 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Inspiron 1545 with several errors; blue screen error code 0xc000014c, diagnostics error code 2000-0146,custom hard drive scan error code 4400:0-000.Should I still be able to recover my files?
Larry Ng
Level 3:
Top Expert:
  • Dell Master 14,601 Answers
  • Posted on Aug 03, 2018
Larry Ng
Dell Master
Level 3:
Top Expert:
Answers
14601
Questions
0
Helped
3279272
Points
66627
Replace the RTC coin cell batter if over 5- 7 years. old. It is that old, so...
test the HDD fully .
using a smart test app.
data is a whole other matter
plug the hdd into a HDD docking bay (buy one)
it uses USB port.
the pull the data off using any other windows based computer that works.
works if lucky bad HDD have bad sectors now and now data is corrupted, the amount of uncorrupted data is not known by anyone on earth , only you, know that doing the work stated. looking and trying to copy data. can work and millions have every day. www.
it's like saying my house was flooded, in a hurricane.
what things in my home my be still good.?
answer only you can look and see.
that is why others asked can not answer any question like that. dell or any other person sitting in a text box 12,000 miles away.
the cure is new hDD, new OS loaded.
data recovery is process endlessly discussed in vast places on earth, google finds millions.
42million hits. today.
https://lmgtfy.com/?q=how+to+recover+data+off+bad+hdd&iie=1
good luck finding data. if the motor is dead there will be no data.
Testimonial: "Great...Best help I have received to date...Much better than Dell support.Thank you!"
  • 1 more comment
  • Doug Hull
    Doug Hull Aug 03, 2018
    HDD still spinning so I will try your suggestions.
  • Larry Ng
    Larry Ng Aug 03, 2018
    if the hdd spins,
    we can test it and even get data off it (pure luck) using any dockbox.
    USB SATA docking station or like kind enclosure.
    and get data from HDD and for sure run the smart test, if parameter C6 is above 0 the HDD TOAST , end of life, Kaput).
  • Anonymous Aug 03, 2018
    http://pcdied.com/HDD-SDD/hdd-bad-v2.htm...
    HDD is easy to test with boot disk. made.
    or move hDD to 2nd pc. and use SATA dock box.
madison smith
Level 2:
Novelist:
Habit-Forming:
  • Expert 88 Answers
  • Posted on Jul 02, 2020
madison smith
Expert
Level 2:
Novelist:
Habit-Forming:
Answers
88
Questions
23
Helped
32828
Points
331
In order to resolve the matter at first, you have to know more about the error code in detail. Basically Windows Error Code 0XC000014C occurs due to several factors that include corrupted boot configuration data issues which happens due to power outage as well as incorrect shutdown process. But don't worry you can easily resolve this issue by following some steps.
Solutions to Troubleshoot Windows Error Code 0XC000014C
Solution 1: Removal of the Windows hardware
Solution 2: Perform a boot process of the last known good configuration feature
I hope you will be able to solve the issue.
  • Anonymous Aug 23, 2020
    when the RTC coin cell goes dead.
    the boot order goes dead (wrong)
    and is not a bad HDD, it is a bad battery.
    if the drive is missing in boot order on any PC made the COIN is next, ()below 2.9vdc is BAd)
    if still dead new coin , the drive is dead.
    if boot files are corrupted next
    then that means 99% the HDD has bad sectors
    and SMART told you that and you should not ignore SMART ever. it did not lie to you.
    bad sectors is a cancer that neither you or I can cure ever, not replacing the drive first.
    c6 PARAMETER NOT 0 MEANS A BAD HDD IS THERE.
    NO IF'S AND';S OR BUT'S, BY DESIGN.
5 Related Answers
Anonymous
  • 165 Answers
  • Posted on Jul 06, 2010
SOURCE: My Dell Inspiron 1545 freezes just after windows s...
This looks like a hard drive failure. Just to be sure, please go through the link below for running and interpreting error codes from Dell. Good Luck.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
www.techtake.net
Anonymous
  • 2291 Answers
  • Posted on Aug 24, 2010
SOURCE: i ran a diagnostic on
check this
http://en.community.dell.com/forums/p/19…
try repair ur os , download reginout that may help u
Anonymous
  • 442 Answers
  • Posted on Dec 25, 2010
SOURCE: My laptop Dell Inspiron 1545
Its time you backup your data and contact Dell to get your hard drive replaced (in case your computer is in warranty) else order for a new hard drive compatible with your computer.
You will need your Windows CD that came with your computer, if you did not get it contact Dell about the same.
Walter H Boehm
  • 998 Answers
  • Posted on Jan 27, 2011
SOURCE: I have a Dell Inspiron 1545. The computer kept
Your hard drive is defective or the circuit (system-board) that controls it. It's cheaper to replace the hard drive then the system-board to see if that's the problem. If it's under warranty Dell will replace either parts.
Anonymous
  • Posted on May 16, 2011
SOURCE: Sudden Blue screen display on
screen display on my
Dell Inspiron 1545 with MS XP OS-
Then I ran diagnostics and got this
result- "DST short Test-Failed-Error
code-2000-0151 Error message:
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Dell Inspiron 1545 red processor:Pentium(R) Dual-core CPU T4400 @2.20GHz is error code 2000-0221, how to solve this problem?
this is a bios level error, you should still be able to run the system. this code is something you get when you hit F12 and run the diagnostics? or is this a blue screen error? you are probably going to need to boot to F2 (setup) then hit "Alt e" Alt F then Alt B the system will beep on the alt f but that's ok once this is done hit esc, save changes and reboot and see if you still get the error
Dell error code 0f00 1322
The drive is bad and will only get worse.
Momentus 250GB 5,400 RPM SATA 3.0Gb/s 2.5" Internal Hard Drive ST90250N1A1AS-RK $50
for more help visit Cbr tech solutions
1helpful
DELL INSPIRON 1545 (Windows 7) My laptop is displaying the message below when switched on: Internal hard disk drive not found. To resolve this issue, try to reseat the drive No bootable devices...
Hi
It seems that the Hard Disk is disconnected from it's connectors
It needs to be fixed and installed correctly.
To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly.
If it's difficult to you, go to technician to do that.
Please, Tell us your results.
Good Luck
I have a Dell Inspiron 1545. The computer kept freezing and with the diagnostics test I received error code on hard drive 0F00:075D
My laptop Dell Inspiron 1545 giving a hard disk drive error. Laptop works normal but sometimes it start producing a sound like tik,tik,tik......... then blue screen appears and when i run diagnostic it...
3helpful
2answers
I have a Dell Inspiron 1545 laptop that won't boot. When i perform a BIOS diagnostic on it it comes up with error code 2000-0146. "Hard Drive 0 - self test log contains previous error(s)". I...
The problem is either the Hard drive has failed and needs replacement or the hard drive is operational but it lost the OS. (Operating System). If the OS is gone, you need to re-install it again..
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
