Question about Ricoh Office Equipment & Supplies
How do i fix Error code SC 521 on a Ricoh Duplicator? (Duplexer jogger driver motor error 2)
    Top Expert:
  • Ricoh Master
  • 84,540 Answers
Posted on Aug 03, 2018
SOURCE:
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 422 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
My ricoh photocopier machine is giving error code 522 pls what is the solution
Quoting link:
"This error is a fusing thermistor error, it can mean:
The fusing lamp is not connected. Reconnecting it may solve the problem.
Thermistor is bent or gone bad. You may need to replace it.
Or, the thermistor position is incorrect.
To try and reset the code press:
Clear Mode, 107, Clear/Stop and hold for 5 seconds."
http://terraofficesolutions.com/forum/index.php?topic=7.0
http://www.thecopierexchange.com/2017/01/updated-ricoh-error-codes/
Code
Possible Causes
SC500Main motor/transport motor lock/Fusing motor error
SC501Drawer 1 lift motor malfunction
SC5022nd or 1st tray lift motor malfunction
SC503Drawer3(or 2nd) lift motor error
SC504Drawer 4 or 3rd lift motor malfunction
SC505LCC Tray malfunction
SC506Paper tray motor lock
SC507LCT main/feed motor lock
SC508Rear fence drive motor
SC509Drawer 3 LCT right fence error
SC510LCT lower limit error
SC511LCC motor lock
SC515Drawer left guide drive motor error, Tandem rear fence motor error
SC516Drawer 1 side guide motor error
SC520Paper tray error/Duplexer jogger drive motor error
SC521Duplexer jogger driver motor error 2
SC522Duplex-Side fence jogger HP error
SC524Duplex-End fence jogger HP error
SC530Bypass feed motor lock/fusing fan motor error
SC531Fuser/Duplexer reversing motor error
SC541Fuser thermistor open/ Hot Roller thermistor open
SC542Fuser Temperature warm-up error
SC543Fuser overheat error1
SC544Hot roller fusing lamp lower limit temperature detected
SC545Fuser lamp overheat error 2
SC546Fuser ready temperature malfunction
SC547Zero cross signal malfunction/ Fusing temperature does not increase
SC548Fusing installation error
SC550Fusing web end
SC551Pressure roller thermistor open
SC552Pressure roller warm up error
SC553Pressure roller overheat
SC554Pressure roller low temperature abnormal
SC555Pressure roller ready temperature abnormal
SC557Pressure roller temperature does not increase
SC558Zero cross signal abnormal
SC590Exhaust/Fusing fan motor error/used toner collection motor error
SC591Toner supply motor error
SC592Toner bank motor error
SC599Copy exit tray motor lock
Troubleshooting Tips:
SC500:Too much load on the drive mechanism
Some gears or other rotating parting has been jammed.
Developing unit is over toned.
Main motor or its driving board is defective.
Before replacing motors or sensors, first check the mechanical load.
SC 541:Fusing thermistor open:
Machine is plugged into low line voltage.
Fixing thermistor is defective or out of position.
Some loose connection
Power Supply board defective
SC590:Left exhaust fan motor error
Loose connection of the exhaust fan motor.
Too much dust in the fan causing too much load on the motor driver.
(e) 6XX: Communication errors
CodePossible Cause
SC600Communication Error Between Main Control and Operation Panel Boards
SC634Key/ Card Counter Device Error
SC636Communication Error Between BICU & Paper Feed Control PWA
SC696Communication Error Between Engine Boad and Finisher
SC621:ADF connection error
An incorrect ADF is installed on the machines.
The connector of the ADF is removed while the machine is in the energy save mode.
(f) 7XX: Peripherals Problems
CodePossible Cause
SC700RADF Original Pickup Malfunction
SC702RADF Feed Motor Lock
SC703RADF Transport Motor Lock
SC704RADF Original Exit Motor Lock
SC705RADF Bottom Plate Motor
SC721Sorter Bin Motor
SC722Finisher/Sorter Jogger Motor
SC727Finisher Stapler Rotation error
SC728Finisher paper stack height error
SC733Finisher Lower Tray lift Motor
SC760ADF Gate Abnormal
SC770Display Editor Abnormal
SC700:ADF pickup problem
Home sensor is defective
ADF board or pickup roller mechanism is defective.
SC733:Finisher lower tray lift motor
stack height sensor or lower tray limit sensor may cause this problem
(g) 8XX: Controller Errors
CodePossible Cause
SC800Startup Without Video output End
SC804Startup Without Video Input End
SC818Watchdog Error, Software Malfunction
SC819Kernel Mismatch, Download Firmware again
SC820Self Diagnostic Error,Download Firmware again
SC855Wireless LAN card problem detected
SC857USB Interface Error Detected
SC868Incorrect Data is detected in the SD card
SC870Address Book Data stored on the hard disk was abnormal
SC 826:Self diagnostic error:
NVRAM on the controller board is defective and must be replaced.
SC855:Wireless LAN card error
Poor Connections between LAN card and the printer
Defective controller board.
Defective wireless LAN card.
Disclaimer:
Please note that this detail is just for information. Do not try to repair a machine if you are not a qualified technician. Technicians should also not take this information as a substitute of technician manuals.
May 02, 2018 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Sc 558 error code on Ricoh Pro C720
SC558 is a Oil supply motor error The machine detects a motor rotation error for 5 seconds after the oil
supply motor has rotated for 5 seconds. ?? Oil supply motor defective
?? Oil supply unit defective
1. Replace the oil supply motor.
2. Replace the oil supply unit.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
What is the sp mode richo aficeowhat is the sp mode richo aficeo
he following error messages will appear on Gestetner, Lanier, Ricoh and Savin products control panel. There are no codes listed in service for operator/user problems. SC-101 Exposure lamp, lamp stabilizer board, dirty white plate, dirty optics, SBU board, CCD SC-103 Power problem SC-104 Exposure lamp problem, main relay optics board, electrical noises or communication error SC-105 Zero cross, main relay, optics board, FUSE 804 on DCPS or AC drive board on FT series SC-120-123 Scan home problem, sensor, scan motor, (EX-IPU board or fuse FU103 Aficio 400, 401, 500) SC-121 Scan home or fuse FU4 Scan home or fuse FU106 Aficio 550/650 SC-124 Scan motor encoder or scan motor SC-125 Scanning to slow speed SC-126 Scanning too fast speed SC-127 Scan motor or optics board SC-128 Scan start speed wrong; motor, board, drive section SC-129 Scan speed problem; motor or PSU SC-130 SBU error SC-140 / 141 Lens vertical home sensor SC-142 / 143 Lens horizontal home sensor SC-144 /145 3rd scan home sensor problem SC-190 EX-IPU board Aficio 400, 401, 500 Optics thermistor FT 7950, 7960, 7970 series SC-192 Automatic SBU adjust error, SBU, BICU, exposure lamp regulator, exposure lamp, dirty white plate SC-193 APS sensor FT 7950, 7960, 7970 series SC-194 IPU white level detect (too low) same as 192 SC-300-303 Charge corona SC-302 Laser (polygon) motor problem SC-302 Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650 SC-303 Charge corona wire cleaner, disconnected or time out for printer SC-304 Charge roller problem, ID sensor problem SC-305 Time out error for memory or EX-IPU board or fuse FU103 on Aficio 400, 401, 500 SC-310-314 Potential sensor SC-320 Laser motor problem SC-321 Laser write problem, BCU board, EX-IPU board SC-322 Laser 1 synch. Problem SC-323 Laser drive problem SC-324 Laser drive excess current draw problem SC-326 Laser 2 synchronization error SC-327 Laser 1 home position error SC-328 Laser 2 home position error SC-329 Laser beam pitch error SC-330 Laser diode no initial setting SC-331 Laser diode home error SC-332 Laser diode present position error SC-335-338 Laser motor polygon problem SC-340 TD sensor output error SC-341 Developer motor lockup TD sensor adjust error Aficio 551, 551P, 700, 700P SC-342 TD sensor adjust error SC-345 Toner collect motor lockup Developer bias loss Aficio 551, 551P, 700, 700P SC-346 Toner recycle motor disconnected SC-350-1: thru 5 ID sensor error SC-351 Vsg problem, bad drum, ID sensor SC-352 TD (toner density) sensor problem or bad toner mix SC-353 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-354 Vsp problem; image density sensor, drum, HVT, developer bias, needs cleaning SC-355 Toner density sensor or under toned SC-356 Toner density sensor or over toned SC-358 Image density sensor, drum, toner spray SC-360 Hard disk drive error 1 SC-361 Hard disk drive error 2 Incomplete drum potential calibration, check imaging formation assembly FT 7950, 7960, 7970 SC-362 Image compression error Hard disk drive error Aficio 551, 551P, 700, 700P SC-363 Data transmission error SC-364 Data transmission time out error Vd out of specs, drum, drum potential sensor, charge corona FT 7950, 7960, 7970 Hard disk drive error Aficio 551, 551P, 700, 700P SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970 SC-366 CRC error Aficio 550/650Vr out of specs, drum, drum ground FT 7950, 7960, 7970 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-367 Hard disk bad sector maximum Aficio 551, 551P, 700, 700P SC-370-01 thru 07 Drum potential sensor error Aficio 550/650 SC-370-374 IMAC error Aficio 551, 551P, 700, 700P SC-376, 380, 382, 384, 386, 388 Data transmission problem Aficio 551, 551P, 700, 700P SC-390 CRC error Aficio 551, 551P, 700, 700P SC-390-1 Toner density sensor error SC-390-2 Toner density sensor error SC-391 Developer bias problem or FU103 on Aficio 550/650 Image storage address error Aficio 551, 551P, 700, 700P SC-392 Toner density sensor SC-395 Developer bias problem SC-400, 401 Transfer roller error Aficio 551, 551P, 700, 700P SC-401 Transfer roller positive error problem SC-401-1 Transfer roller/belt short SC-401-2 Transfer roller/belt open or fuses FU104, FU115, FU116 Aficio 550/650 SC-402 Transfer roller negative error problem or open SC-403 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Transfer belt position error, electromagnetic clutch release or fuse FU5 SC-405 Scanner problem; BCU, EX-IPU board or SCU on Aficio 400, 401, 500 SC-411 Separator bias SC-430 Quenching lamp error SC-440 Main motor locked or drum motor locked SC-441 Developer motor locked SC-490 Exhaust fan problem or ozone fan problem SC-491 Laser cooling fan locked SC-492 Cooling fan problem SC-493 Bridge fan problem Exhaust fan locked Aficio 551, 551P, 700, 700P SC-494 Fuser fan locked SC-495 Toner recycling unit problem SC-496 Toner collector bottle problem SC-497 Toner recycling motor problem SC-500 Main motor locked Bypass motor locked FT 7950, 7960, 7970 SC-501-1 & 2 1st Tray lift problem SC-502-1 & 2 2nd tray lift motor problem SC-503-1 & 2 3rd tray lift motor problem SC-504-1 & 2 4th tray lift problem SC-505 LCT tray SC-506 Optional tray motor locked SC-507 LCT motor locked SC-508 Tandem rear fence motor SC-509 Tandem side fence motor SC-510-1 & 2 LCT lift problem Paper feed motor problem Aficio 551, 551P, 700, 700P SC-511 Tandem side fence motor error LCT motor error Aficio 551, 551P, 700, 700P SC-515 Tandem rear fence motor Aficio 551, 551P, 700, 700P SC-516 Tandem side fence motor Aficio 551, 551P, 700, 700P SC-520 Duplex or fuser drive problem FT 7950, 7960, 7970 SC-521 Duplex side fence drive problem SC-522 & 523 Duplex jogger home position FT 7950, 7960, 7970 SC-524 Duplex end fence drive problem SC-530 Bypass motor locked or fuse FU106 on Aficio 551, 551P, 700, 700P SC-531 Fusing duplex motor locked SC-541 Fuser thermistor open SC-542 Fuser temperature too low or fuse FU107 on Aficio 551, 551P, 700, 700P SC-543 Fuser temperature to high SC-544 Fuser temperature too low SC-545 Fuser temperature to high SC-546 Fuser ready temperature unstable SC-547 Zero cross problem Fuser lamp stays on, AC drive board, optics board FT 7950, 7960, 7970 SC-548 Fuser unit not installed SC-590 Toner collector motor problem Cooling fan Aficio 220/270 series SC-591 1 bin tray motor SC-600 Communication problem between SCU and operation SC-601 Communication problem between BICU and scanner Communication problem between BCU and EX-IPU board Aficio 400, 401, 500 Communication problem between SBU and SBICU Aficio 550/650 Communication problem between MCU and BICU Aficio 551, 551P, 700, 700P SC-602 Communication problem between BICU hard disk drive board Communication problem between BCU and fuser control unit on Aficio 400, 401, 500 Communication problem between Hard disk drive board and SBICU Aficio 550/650 Communication problem between BICU and hard disk drive board Aficio 551, 551P, 700, 700P SC-602-2, 2, -3 Communication problem between BICU and ADF SC-604 Communication problem between BCU and high voltage board SC-605 Communication problem between SCU and BCU SC-610 Communication problem between IOB and duplex unit SC-610, 611, 612 Communication problem between BICU and ADF SC-620 Communication problem between BICU and ADF SC-621 Communication problem between BICU and finisher SC-623 Communication problem between BICU and paper tray unit SC-624 Communication problem between BICU and LCT SC-625/626 GA5 data transfer error; EX-IPU or software Communication problem between BICU and finisher Aficio 551, 551P, 700, 700P Communication problem between BICU and LCT Aficio 1035, 1045 SC-627 Communication problem between BICU and LCT Aficio 1035, 1045 SC-630 Communication problem between line adapter and CSS center (Japan) SC-635-636 Communication problem between BICU and paper feed board Aficio 551, 551P, 700, 700P SC-640 BICU data transfer sum check error SC-641 BICU control data transfer problem SC-650, 653 Key card (Japan) SC-670Engine or BICU error SC-672 Op panel to controller problem SC-690 BICU problem (12C) SC-691 Communication problem between BICU and fax controller BICU problem (12C) Aficio 1035, 1045 SC-692 Communication problem between BICU and print controller board BICU problem (12C) Aficio 1035, 1045 SC-694 Communication problem between BICU and scanner board SC-696 Communication problem between IOB and finisher SC-700 ADF P/U problem SC-701 ADF P/U problem SC-702 ADF feed in motor SC-703 ADF transfer motor SC-704 ADF feed out motor SC-705 ADF bottom plate motor SC-720 Finisher transport drive motor problem SC-721 Finisher tray shift or shift motor problem SC-722 Finisher jogger motor SC-723 Finisher stack feed motor problem SC-724 Finisher stapler hammer motor SC-725 Finisher stack feed out motor SC-726 Finisher shift/lift motor SC-727 Finisher stapler rotation motor SC-729 Finisher punch motor SC-730 Finisher stapler position motor SC-731 Finisher exit guide motor Finisher exit open/close motor problem Aficio 1035, 1045 SC-732 Finisher up tray shift motor problem SC-733 Finisher stack feed out motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-734 Finisher lift motor Finisher lower tray shift motor problem Aficio 1035, 1045 SC-735 Finisher exit guide motor Finisher pre-stack motor Aficio 551, 551P, 700, 700P SC-736 Finisher exit guide plate motor SC-737 Finisher waste stapler full SC-738 Finisher shift tray lift motor SC-740 1000 sheet finisher error 01: Shutter error 02: Exit error 03: Upper exit plate error 04: Jogger motor 05: Stapler motor 06: Stapler hammer motor 07: Tray lift motor 08: Shift tray height sensor 09: Back up RAM 0A: Communication error SC-741 1000 sheet finisher error in saddle stitch area o 01: Position plate motor o 02: Folder roller motor o 03: Shutter guide motor o 04: Booklet jogger motor o 05: Stapler motor o 06: Folder plate motor o 07: Connector o 08: Switch SC-750 Interchange connection problem SC-751 Bridge connection SC-752 Finisher connection SC-760 ADF gate problem SC-770 Shift tray motor SC-800 Control board bad SC-804 Control board bad SC-819 Software application error SC-820 Control board or software SC-821 Control board SC-822 Bad HD SC-823 Bad control board or NIC SC-824 NVRAM or battery bad SC-826 NVRAM bad SC-827 Memory problem SC-828 Bad control board or firmware SC-829 RAM DIMM or control board bad SC-835 Control board or connector SC-836, 837 Font ROM bad SC-838 Clock generator problem SC-850 NIB or control board bad SC-851 IEEE 1384 interface board or control board bad SC-860, 861 Hard drive problem, connection or cable SC-862, 863 Returned, Bad sector in hard drive SC-864 Abnormal HD data transfer SC-865 Hard drive error SC-900 Electrical copy counter problem reached 10 million or NVRAM problem SC-900-01 Mechanical counter SC-901 Mechanical counter or fuse FU4 SC-921 MSU hardware error Copier feature expander hardware error Aficio 220/270 SC-940 Main switch problem or main board SC-951 Gate signal error SC-953 Scanner image setting error (Software) SC-954 Printer image setting error SC-955 Memory setting error SC-956 Scanner parameter error SC-957, 958 Scan error SC-959 Printer setting ID error SC-960 Printer return ID error SC-961 Printer ready ID error SC-962 Memory setting ID error SC-963 Memory finishing error SC-964 Printer ready error SC-970 Scan error SC-980 Program loading error or hard drive access error SC-981 Hard drive response error SC-982 Hard drive construction error SC-984 Hard drive response error Control board, BICU or connection bad Aficio 1035, 1045 SC-985 Control board, BICU or connection bad Aficio 1035, 1045 SC-986 Software problem SC-990 Communication problem between BICU and input output board or software performance error SC-991 Software problem SC-996 FCU board or firmware problem SC-997, 998 Software or missing RAM or missing DIMM SC-999 Program version error or fuser FU6 Program download problem, BICU, IC, NVRAM bad, power loss, board installed wrong Aficio 1035, 1045 Printer Controller Error Codes 2001 Power on error 2002 FGATE error 0201 On board SDRAM error 0301 SDRAM error 0Fxx Controller -BICU error 1101 Data transmission error 1102 Data loop back 11xx Centronics cable error 1401 Controller NVRAM error 1402 NVRAM check sum error 1403 NVRAM white error 1404 NVRAM read error 1501 RTC error 1601 Font ROM error 1602 Data in font ROM is damage 1Bxx Options bus A error RICOH 3813 Copier U1 Right side open U2 No key counter U4 Sorter not latched or closed U6 Developer unit not in place E11 Exposure lamp problem E12 Exposure lamp problem E13 Zero cross, main board or power supply E-14 Zero cross, main board or power supply E-21 Scan home problem E-22 Scan home problem E-28
May 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
SC 521
Duplex jogger moter Error2
when the hogger fence moves from the home position the jogger fence HP sensor dosent turn off even if the jogger motor has moved the jogger fence 153.5 mm.
ypu need to replacee the sensor
Sep 08, 2008 | Ricoh Aficio 1085 Laser Printer
483 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
