Question about RCA DRC8295N DVD Recorder/VCR
Disc shows Reading disc and will not open - RCA DRC8295N DVD Recorder/VCR
  • 10,515 Answers
This is sure a mechanical problem. Try some Lubricant on the motor.
Just take off the cover and the tray face plate and usually the interface plate ,being very careful not to pull on any strands in there.
You can then insert a Dvd and see if t it will start to spin when you close the tray. If not put a drop of some thin lubricant on the (Spinner?)and let it settle for a bit and spin the mechanism manually for a while.
If you open and shut the tray and start to manually turn it you should feel that it wants to turn by itself.
What finally worked for me was to put in a less useful dvd (due to the oil) and manually spin it after the laser engaged.
After a few drops and repeating this procedure, it might fix the problem.
If you are unable to open the tray, Power off the DVD. Plug in after 20 minutes. If still unable to open it, open the tray and manually eject the disc and follow the above procedure.
In case, if the problem still persists, more likely it's due to faulty Lense. You need to get it replaced.
You can try one more trick, if that works :-
1)power-off power-on
2)put in a regular non-recordable dvd
3)Wait for it to recognize that dvd. Sometimes you need to try this a couple of times as you pray to the God of dvd burners to let your dvd burner work; all while the first 5 minutes of the season premiere of your favorite show goes by unrecorded.
4) Once this dvd is recognized, eject it, and put in your recordable DVD. If it recognizes it, don't touch anything, don't power-off the machine, start recording immediately.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 02, 2009
RCA 5 disc Changer RS2600 stop reading the cd and and shows "no disc"
The reading eye is most likely dirty and doesn't see the disc clearly. If you can clean it with alcohol on a long QTip, you might get it work again for a while. Dirt & dust are the worst on the opticals. If you can clean it yourself great. Many can't be done without taking the case cover off.
Nov 24, 2012 | Audio Players & Recorders
When i turn on my xbox and go to xbox live the box where it shows the game you have in. mines blank and i put any game in, doesnt matter what kinda game or anything and it says reading..............then...
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 White Console
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Cannot read disc
The reason your DVD player is not reading disc is because the lens is not reading the disc.
The reason the lens is not reading the disc is either because the lens is weak or dirty.
Try to clean the lens with a lens cleaner.
test it with a DVD, to see if it will work.
If it does not work, then the lens is weak and needs replacement.
to replace the lens,
open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
take care
Jun 15, 2010 | JVC DR-MH30S DVD Recorder
Keeps saying wrong disk
The reason it is showing wrong disc is because the laser/lensisnot reading the disc.
The reason the laser/lens is not reading the disc is because it is either weak or dirty.
To fix it if it is dirty, try to clean it with a lens cleaner.
If it does not work, then it means the lens is weak, and to fix the lens you have to replace it with a new compatible lens.
Get the appropriate screwdriver, open up the cover, unscrew the disc tray and try to locate the lens and replace it with the new one.
test with a DVD disc.
Take care
Jun 13, 2010 | GPX D1816 DVD Player
Disc door will not open
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
New disc will not format
Go to my computer, then find your dvd drive, right click, go to properties and make sure the Read Only and Write Only boxes are UNCHECKED. Then apply and hit ok and try again
Aug 24, 2009 | Televison & Video
PS2 HELP WANTED!!!!!!!
my friend had the same problem what he had to do was keep opening and closing the disc tray untill the 'reading disc' shows up and stays up but he got really anoyed with doing this so he got a new one shortly after this the ps3 came out...
Jun 17, 2009 | Sony PlayStation 2 Slimline Console
Kenwood dv-505 door will not open
THERE IS AN EMERGENCY OPEN OPTION ON MOST ALL DISK DRIVES, LOOK RIGHT BELOW THE DRAWER USUALLY TO THE RIGHT FOR A SMALL PINHOLE. GET A PAPER CLIP AND STRAIGHTEN ONE END OUT, INSERT STRAIGHT INTO HOLE UINTIL YOU FEEL IT STOP AT THE MANUAL RELEASE CATCH AND GENTLY PRESS UNTIL YOU HEAR THE DRAWER BEGIN TO OPEN.
BLOW ANY DUST OUT, AND CHECK THE PC AND DRIVE WEBSITE FOR A POSSIBLE FLASH UPDATE FOR YOUR DRIVE MODEL. THEY ARE OFTEN POSTED WHEN DRIVES SHOW PROBLEMS READING SOME OF THE NEWER DISK BEING MADE. THIS HAS WORKED FOR ME A FEW TIMES IN THE PAST.
Feb 13, 2009 | Compaq Evo N610C Notebook
RCA DRC8295N DVD Recorder/VCR Logo
134 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
