Question about Sony Playstation 3 (PS3) Console
My ps3 just powered down during a game and we tried unplugging it and turning it on and off but all that happens is the red power light comes on so we turn it on. The light turns green then automatically powers off again. It won't even let us get the game out!
  • 98 Answers
Leave it to cool down and always keep your machine well ventilated. It has a protection against overheating and it will shut down by itself. Clean out the vents with compressed air then vacuum out the rest as best as you can just by sucking whatever you can out of the vent holes.
Posted on Aug 03, 2009
I was playing a game then the ps3 shut off. now i can't get the ps3 to load. i tried unplugging everything and restart the ps3. i tried plugging it in a different outlet. i cut the ps3 off in the back,...
Do you have the red light of death I wonder??? What happens when you switch on your ps3. Does the green light come on, then beep at you and then does it go back to the red light? If so your ps3 is knackered!
Apr 10, 2011 | Video Game Consoles & Games
My PS3 keeps cutting off by itself. It will cut off while I play a game and the red standby light cuts off as if the power cord is not connected. Then, when I try to unplug it and plug it back in, the...
ok whats happened there is your ps3 power cord has become a bit loose in their so get a expert to fix it
i would always recommend a expert to do it never do it unless you know what to do
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
My PS3 isn't getting power. The red light was
may have bad motherboard and or bad powersupply box. If it makes a popping noise when you try to turn on then you have problem with your power supply box. I would send it for repair.
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on help
try unplugging the power cord from the ps3 and putting it back on. if that doesnt work, your console might have kicked a breaker in your homes breaker box. on the ps3, always turn it off by the the back power switch.
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Red flashing light, won't power on My PS3 60GB has just switched itself off in the middle of a game!! Red light is flashing on the front and it won't come back on!! What is the problem?
Try turning the power off at the back and leave it unplugged for 10 minutes.
How long has it been running for without being turned off to cool down?
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
114 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
