Question about Metra 92 95 Cadillac Eldor/Seville
I can't find the transmission dipstick to fill the trans on a 94 cadilac eldorado
    Problem Solver:
  • 6 Answers
I believe the transmission fill plug acts as the dipstick as well...facing the V8 Northstar motor look straight down on the transmission end (right sight) and you'll see the fill plug.
Posted on Aug 10, 2009
Where is the transmission oil pan located on a 95 ford probe??
it fills through the dipstick tube, with engine running,
Apr 13, 2014 | 1995 Ford Probe
What is the correct transmission oil level?
you measure the trans level by pulling the trans dipstick with the car warmed up (after a short drive), on level ground, engine running-it should read within the 'hash marks' on the dipstick to be considered correct
Mar 10, 2011 | Toyota Corolla Cars & Trucks
Wheres the transmission dipstick located
the trooper has no dipstick for trans its a sealed system on the trans pan you will find a fill plug and a drain plug the one on top inrecess is the one your looking for with the truck in park running remove fill plug fluid level should be just below that hole you can use ur finger to tell
Hope this helps
Positive Feedback ALWAYS appreciated :)
Mar 03, 2011 | 2000 Isuzu Trooper
I need to fill the transmission fluid on my 94 trooper but cannot find the filler cap
Remove the transmission dipstick, get a funnel and pour it down the dipstick housing. Replace dipstick and check frequently until full. Hope this helps!
Dec 26, 2010 | 1994 Isuzu Trooper
Where is the fill hole for 2005 cadilac cts transmission
I am assuming that the transmission is an automatic. If so, the fill hole is the tube where the transmission dipstick is located. Simply remove the dipstick and using a funnel, slowly pour in the transmission fluid. Remember...do not overfill the transmission.
Nov 14, 2010 | Cadillac CTS Cars & Trucks
94 Pathfinder, Manual transmission slipping a tiny bit. I want to add Lucas Stop Slip. How do I do this. Theres no Dipstick to check levels of TRANS FLUIDS
Adding Stop slip to a manual transmission with not keep your clutch from slipping. Replace or adjust the clutch.
Mar 13, 2010 | 1994 Nissan Pathfinder
Checking fluid in transmission
There is no dipstick on a manual transmission. On a manual tranny, you check the fluid by pulling the fill plug on the side of the transmission. The fluid is supposed to be even with the bottom of the fill plug hole. Gently stuck your finger in there and on a fully serviced trans. you will feel the fluid on your finger tip. On an auto transmission the dipstick is on the passenger side near the exhaust manifold close to the firewall. Also you fill the trans thru the dipstick. Make sure you use the proper fluid and the correct amount.22
Jun 04, 2009 | 2004 Ford Explorer
Dipstick
If it is an automatic, which I assume it is since you're looking for a dipstick, it needs a special fixture to add fluid(Dealer or foreign auto mechanic) or check level. If it's a manual trans, there is a check/fill plug on the end of the transmission behind the driver's side front tire, probably takes a 17mm internal hex head socket. Use 75W/90 gear oil, filling the trans until oil just starts to overflow through the hole.
Jan 05, 2009 | 1996 Volkswagen Cabrio
No transmission fluid Dipstick on my 2007 Ford Fusion
depending on which trans it is there is a small dipstick on the trans at the front on the bottom these transmissions take a specific fluid so be careful
Nov 17, 2008 | 2006 Ford Fusion
Gear fluid
Most automatic transmissions do not have a filler plug or cap. The transmission fluid is added by using a long-neck funnel, which is placed in the tube the dipstick for the transmission sits in. Be sure to test the level while the engine is running, with the transmission in either park or neutral. Be very careful not to over fill the transmission, and make sure that you have the right kind of transmission fluid for your vehicle.
Jun 23, 2008 | 1994 Honda Accord
Metra 92 95 Cadillac Eldor/Seville Logo
116 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
