Question about York Yankees Bedding MLB Comforter
Heat pump will not come on when cooling call for by t'stat. Indoor fan runs and heat pump runs when contacts manually closed but not from t'stat signal.
  • 32 Answers
There are several possibilities the first thing to check is to make sure you are getting low voltage to the control board,if there is no voltage then is a problem with the wire coming from the t-stat,or the t-stat itself, if there is low voltage (at least 24) then you have a faulty control board.
Posted on Sep 04, 2009
Indoor blower won't shut off on heat pump
I would look to replace a relay that is not shutting off or replace the thermostat itself.
Nov 14, 2015 | Honeywell Heating & Cooling
Goodman gph1348m41ac unit is blowing cool air in heat mode with mid 30s ambient outdoor temp. I turn it off then on and will usually blow warm air but this cycle is becoming more repetitive. any expert...
A heat pump on the optimal heating day (about 50 degrees ambient) will only deliver approximately 85 degree air as compared to 125 degree air from a fossil fueled furnace. The colder the outdoor air is the less heat there is available to be transferred to the living space. At 30 degrees, the heat transfer capability is getting close to negligible meaning the run cycles will be approaching continuous and eventually as the heat pump along cannot maintain setpoint, the outdoor stat or stats will bring on auxilliary heat in the air handler.
If your ambient temp is below the 'balance point' of the heat pump, the house temp will drop a little lower and most times energize the heat strips through the outdoor t-stat. Your outdoor stat could be set too low for the heat pump to carry the structure all the way down to the balance point so when you turn it off and back on, the lower indoor temp automatically brings on the heat pump plus a heat strip or two, thus the warmer air. Second stage on the stat satisfies due to the heat strip, drops them out of the circuit and the heat pump is left running on first stage heat delivering the perceived cold air.
Your outdoor stat could also be not functioning correctly and not allowing the heaters to come on until the system is turned back on reestablishing the two stage call for heat.
Tons of possibilities and not enough room to list....
Jan 01, 2015 | Goodman Manufacturing Goodman GPH1348M41 4...
Indoor blower wont run on cool cycle
sounds like a wiring problem. the t-stat fan on position uses high speed on fan as does the call for cool. possibly a bad t-stat.
Apr 08, 2014 | Goodman Heating & Cooling
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
I bought the amcorair one of the inside units is not working right. IT IS SET ON 72 degrees and it does not cut on even at 66 degrees.
Hi, from what you are saying, it sounds as though you have a control/thermostat problem. You say it doesn't work right, so I am assuming it does work, but just does not come on when the stat calls for heat. Make sure you have 24 volts to the stat. Turn the fan to the on position to see if it comes on. If so, you have power. If the heat is not coming on at 66 degrees, and you have it set to call for heat below 72, you do have a problem with this stat. The room sensor is mounted in the circuitry of the subbase, or second section of the thermostat. There is nothing you can do to repair this stat, your only option is to replace it. If you have both heating and air, you will need a stat for that. If you have gas heat get a regular central heat and cooling stat, 24 volts. If you have a heat-pump, you will need a heat pump stat. The best thing to do, is shut off the power to the indoor unit. Remove the first section of the stat, it should just unsnap. You may need to pull some to get it off. Then you will see the subbase with the wire terminals. If you have gas heat, it will be marked something like this. RH to RC with a red wire connecting the two. You will have a smaller red wire coming in from the indoor unit which can go to either one. You will see Y yellow for cool, W white for heat, G green for fan. If its a heat pump stat, you will have many more terminals such as o/b, may have E and C, w-1, w-2. Draw you a diagram of the wiring and the terminals they go to. Now, remove the subbase. It will be held to the wall with a couple of screws. Take it with you, and go to Home Depot, Lowe's Hardware, O.S.H. to get a stat. Try and find the same one, but it will not matter as long as you have the same terminals. Many stats will work on many units. Install it in the reverse order. This drawing is very important for you. This will indeed solve your problem, and is very simple to change out. If you have any questions when doing this, please contact me, as I will check in on you. It may take time for me to respond if I am on another call. Please don't forget to rate me on this, I know you will be kind! :))
Sincerely,
Shastalaker7
A/C, & Heating Contractor PS, Don't loose the manual for your new stat!! Put it in a safe place, this is very, very important.
Nov 21, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I switched my thermostat to save money but now it is 85 in my house and it constantly is running but it is hot all the time my dad put it in so i know its right what is wrong with it
It may be wired incorrectly. Make sure that the compressor is being called to run when you set the ac to cool. The Green wire to T-stat makes the indoor fan run when you set the T-stat to cool...also the Yellow wire should signal the contactor to engage at the outside condenser and compressor unit. If this is a heat pump system there is usually an orange wire that will signal the reversing valve to move when cool is being called....normally the reversing valve is in the heating position in the event there is a failure to the solenoid that actuates it..thus leaving it to fail in the heat mode to provide heat in winter weather as a default. Make sure the new T-stat accomidates for your units wiring.
Red wire to R (24v supply from transformer)
Green wire to G (indoor fan)
White wire to W (call for heat)
Yellow wire to Y (call for cool)
Blue or Black wire to C (common)
Orange also to Y if not specific to t-stat (calls for reverseing valve in cooling mode)
Oct 13, 2010 | Heating & Cooling
A/C does not cool like it used to, unit runs
sound like your system is under sized. for every 400 sq ft of living space you should have a ton of ac or 12000 btus. also check and see if your attic fan is working. any drafty windows or doors. your supply temp should be at least 20 deg colder then your return temp. also check your filter should be changed every three months this will help with air flow.
Jun 07, 2010 | Carrier 38CKC042 Air Conditioner
My indoor unit on my heat pump will not shut off. The electric heat keeps running, and the fan keeps running. It only happens when it is really cold, like 25deg or below, above that and it functions fine....
I would venture to say your stack relay is getting stuck. either that or you have a short in your low voltage wiring somewhere that is not always making contact....or it may be making contact through another median...like ice or frost. Remember electricity takes the path of least resistance.
But I would check the relay first. If its a stack relay or a closed type relay, try putting in a contactor that you can visually see if its closed or not.
Feb 01, 2010 | Intertherm P3RA-036K Air Conditioner
It's cold out, and my Central Air kicks on every time my furnace kicks in. I get heat, but don't think my outside unit (fan) should be kicking in each time my furnace kicks on. Suggestions
Hi, If you have what is called a heat pump, the outdoor unit is supposed to run. It has a reversing valve which reverses the flow of refrigerant and the indoor unit becomes the condenser and the outdoor becomes the evaporator coil. Now, if you don't have a heat pump and the furnace is gas fired, then the control wiring or thermostat is calling for both to come on. Control wiring has to be touching together somewhere and bringing on both. Look over the exposed stat wire outside if you have a dog that may have chewed the wires, I have seen this happen. If all wiring looks good, then the stat is faulty and must be replaced. Make sure you don't have a heat pump first, as the fan, compressor, and all will run on heat and cooling. I hope this will solve you're problem, please let me know, I would like to hear back. Sincerely,
Shastalaker7
Nov 20, 2009 | Heating & Cooling
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
York Yankees Bedding MLB Comforter Logo
153 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
