I HAVE NO IMAGE ON MY COMPUTER FOR ME CAMERAS. THE TIME COUNTER APPEARS BUT NO IMAGE. ANY ADVICE?
  • 11,896 Answers
Update the drivers and turn camera on before connecting.
Posted on Aug 02, 2009
When trying to print more than 10 copies at a time, error code c-2558 appears and it stop printing..means it can only print 9 or 10 copies at a time but not more than that then error code appears
Code C2558 Description Abnormally high toner density detected TCR sensor
• TC ratio in the developing unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively. Remedy 1 Make sure that the following counter is cleared at the developer replacing. [Service Mode] - [Counter] - [Life] - [Developer Use Time] 2 Perform image troubleshooting procedure if image density is low. 3 Reinstall developing unit. 4 Reinstall toner bottle. 5 Check the contact of developing unit for proper connection and correct as necessary. 6 Check the connector between TCRSB CN29-relay CN28-PRCB CN24 for proper connection and correct as necessary. 7 Check the connector between M3-PRCB CN8 for proper connection and correct as necessary. 8 Check the connector between M4-relay CN13-PRCB CN8 for proper connection and correct as necessary. 9 M3 operation check. 10 M4 operation check. 11 Change developing unit. 12 Change TCRSB. 13 Change PRCB.
Feb 10, 2016 | Konica Minolta "Minolta Bizhub 363 Copier,...
Picture image out of alignment
Your viewfinder, focussing screen, and mirror are out of alignment. You need a service technician to fix the problem.
Jul 04, 2010 | Sony Alpha DSLR-A350 Digital Camera
I have a Canon EOS 400D. Photographs are appearing with what looks like round marks or bubbles in the image. I've cleaned and changed the lenses but it still appears. I am wary about cleaning inside the...
There is a mode in which you can lock up the mirror and shutter blades so that the sensor is exposed. Use a appropriate cleaning kit and avoid touching the sensor.
Jan 01, 2010 | Canon EOS 400D Digital Camera
When I power up the camera, an image appears and
This old picture is on your internal memory. To remove it, remove your memory card...turn on the camera...go into the menu and find "format"...follow the on-screen instructions.
Dec 26, 2009 | Pentax Optio S5z Digital Camera
DSC-T20 Sony Cyber Shot Camera that vibrates like a cell pohne. The vibration does not allow for a good picture it all. Could it that the anti vibration system of the camera goes into a full mode trying to...
Hi!
The problem you have is a faulty image stabilizer. It's a well known problem in these cameras. It's a hardware fault and I'm afraid you won't be able to fix it yourself. Usualy it requires the lens unit to be replaced. You should contact your local Sony service center or me at toms.safranovs@gmail.com - I give the best prices. ;)
I work in a Sony service center.
Hope this helps!
Tom
Jul 29, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Can not get dates to show up on photos
You can embed the date on image data when (Postcard) is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Cannot delete photos" Card Protected" appears on screen
There should be a small switch on the memory card that allows users to lock it so no one can delete pictures on it. Take the memory card out of the camera and look for this switch on the card and make sure it is not in the locked position.
May 19, 2009 | Sakar 87492 Digital Camera
I have a finepix s700 and want to print with date and time. help!
The S700 doesn't have a date print function (so that the date appears on the image). Are you printing yourself, or having a lab print the photos for you? Some inkjet (home) printers can print the date on the image or on the border. Many labs (my Fuji Frontier digital lab, for instance) can print the date on the print for you, as the data is contained in the file data. Ask at the lab counter. They also shouldn't charge for this service, as it's a one-button operation.
Feb 25, 2009 | Fuji FinePix S700 Digital Camera
Will not record nor replay.
I Had The Same Problem I Just Turned The Screen A Different Way And It Worked Again
Jan 07, 2009 | Video Cameras
D40X LCD: Initial display time?
In your custom settings no 15 Auto Timers you can set the time.
Brian Mason
Dec 08, 2007 | Nikon D40x Digital Camera
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
