Question about Sony XM-2002GTW Car Amp
I have 4 8ohm speakers now the speakrs work in 2ohm how i can put the amp to work at 2 ohm the amp is a sonyxplod xm2002gtw
  • 11,896 Answers
It will only work in 4 ohm
Posted on Aug 02, 2009
Wire 2ohm or 4 ohm
wiring depends on what amplifier you're using..
Dec 28, 2013 | Pioneer TS-W3004SPL Car Subwoofer
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
Amp goes into protection mode when i turn up volume
Sounds like you are running your subs at to low of ohm. Amps are rated differently on the levels of ohms or resistance that they can get to. If you have a dual 4ohm sub and run it in pairrell it will drop to 2ohm and if you run the same sub in series it will be 8ohm. Your amp will go into protection if the ohm is to low.
-david
Nov 07, 2010 | Jl Audio 12W6 Car Subwoofer
How many speakers and woofer solid audio f2000 2 channel amp can support ?
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Jul 11, 2009 | Solid Audio Formula Series F2000 2-Channel...
    How do you wire up a dual voice coil lanzar 15 for 4 ohm?
    Hello dexterchapma,
    The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
    Hope this helps.
    Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
    Jl audio 10w6 x zapco350
    These subwoofers are dual 4 ohm voicecoils.
    Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
    Connect both + on the sub to the + on the amp.
    Connect both - on the sub to the - on the amp.
    Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
    Thank you for using FixYa - a FixYa rating is appreciated!!
    Jan 27, 2009 | Jl Audio 12W6v2 Car Subwoofer
    I have two 15inch l7 subs 2ohm
    With 2 ohm dvc a sub can output either a 1 or 4ohm load.therefore with 2 subs you end up with 2ohm or 8ohm load.Of course you'll use the 2ohm connection which is this.....
    Take one sub and connect the (-) with the other (-) and the (+) with the (+).
    Do the same with the other sub.Each sub now carries out a 1ohm load and you end up with 2 pairs of cable.Now take one(+)and put it on the amp.Take the (-) from the OTHER pair(this is critical) and connect it on the amp.You will still have a(-) from the first pair and a (+) from the other pair!Well....connect them together!!!Thus you'll have a 2 ohm load on the amp!
    Nov 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    I want to know how to wire a speaker
    Weather of not you can use this speaker as an extension cab depends on a number of things. First, what amp are you planning you use for it? What is the minimum resistance for this amp (2ohm or 4 ohm probably). Second, what is the primary cab you are using ans what is the resistance on that? (2ohm, 4ohm or 8ohm).
    Is there just one speaker in you proposed extension cab? The goal is to have all the speakers wired in parallel without lowering the resistance to a point that will damage the head. So if your amps minimum resistance is 4ohm then your cabs will have to both be 8ohm, running in parallel the overall resistance will be 4ohm.
    Oct 04, 2008 | Music
    Two amp
    I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
    Geno
    Feb 27, 2008 | Harman Kardon AVR 630 Receiver
    Sony XM-2002GTW Car Amp Logo
    61 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Philip Rowney
    Philip Rowney
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
