Question about Dell OptiPlex GX260 PC Desktop
When powered up the amber light stays lite, fan runs but will not start up.
    Problem Solver:
  • 16 Answers
Go component by component to find the issue. Bring it down to nothing but the MOBO, removed the battery to reset the CMOS, listen for BIOS beep for no-memory. Added the RAM, see if that checks out and continue until it won't boot and you will know what component is bad.
Posted on Aug 02, 2009
Try changing your ram and that'll solve the problem
Posted on Sep 02, 2009
Optiplex 320 wont boot. Amber power light and fans running
power off 1st..then open ur cpu ..check ur ram ...and clean it....or mother board is not work replace near hardware shop....or check ur bios bettery or change it
Feb 17, 2012 | Shuttle sn Computers & Internet
Dell c521 motherboard diagrams problems
Per Dell's support site: If the power light is a solid amber, a device might be malfunctioning or incorrectly installed.
Turn off the computer and unplug from power:
I would remove and unplug everything except the memory and video card. Then plug the computer back in.
If it posts (dell screen and then a hard drive warning), turn off the computer and start reinstalling each component one at a time and turn on between each install. Hopefully one compenent will fail and you will know what is bad and needs replacing.
If the computer still had the amber light, remove one of the memory modules (hoping you have 2) and try again. If it still fail exchange the modules. If this works you have a bad memory chip, reinstall the rest the componets to double check and power on. Replace the bad chip.
If the computer still fails on both modules, remove both, you should now get a memory beep code, if not then the video card is most likely bad and will need to be replace.
Hope this helps
Jan 31, 2012 | Dell Dimension C521 PC Desktop
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
Computer wont power up. Light stay amber and fan come on
Hi. No I think mobo is ok as you've got power to fan and lights. Are the drives kicking in? if yes then I think its your memory. Also if the drives are kicking in then your cpu is also ok. So that leaves the memory and graphics card. Good luck
Mar 31, 2009 | Dell Dimension 3100 PC Desktop
Windows XP won't start
The amber light is the error light on a Dell. It can mean a few things. 1. RAM has went bad, not properly seated. 2. Video card has went bad or come unseated. 3. Power supply is not working properly; or 4. Motherboard has went bad. Hope this helps & please remember to rate my answer.
Jan 02, 2009 | Dell Dimension 2350 PC Desktop
Amber Light and fan running
1st thing, disconnect everything but keyboard mouse and monitor, see if anything changes.
If the issue persists, ensure that all power and card connections for the motherboard are tight and secure. If you've added RAM or other parts, remove them. Reseat the RAM in the motherboard that came from Dell.
If none of those ideas have any effect on the issue, replace the motherboard.
Jul 01, 2008 | Dell Dimension C521 PC Desktop
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
260 people viewed this question
Alun Cox
