SOURCE: roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
SOURCE: Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
SOURCE: Roper washer will not spin or drain-
you may have something stuck in your pump, preventing it from draining. The washer will not spin until it does drain. You'll have to empty the tub (you can do this with gravity by taking the drain hose and putting it down near the floor in a bucket). You will have to take the cabinet off, then take the hoses off the pump. Have some towels ready! Look inside the pump and hoses for an obstruction. If the fins inside the pump are damaged, you will have to replace it. If there is no obstruction here, look down inside the hose drain. Run a coat hanger down if neccessary to see if theres a blockage. The pump could be dead, too.
You could have a dead spot on the timer, but this is doubtful.
SOURCE: my roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling
If the washer won't spin or agitate the motor
coupling might have failed. The motor coupling connects the motor to
the washer transmission. It is designed to fail if the washer is
overloaded in order to protect both the motor and
Drive Belt
If the washer won't spin or agitate, check
the drive belt. If the belt is broken or if it isn't tight on the
pulleys the washer won't spin or agitate properly.
Drive Motor
If the washer won't spin or agitate the drive
motor might be defective. This is not common. Check all of the other
related parts to this symptom before replacing the motor. If the motor
is visibly burned out or physically damaged, replace it.
Stator Assembly
stator assembly might be burned out. The stator is essentially one half
of a motor, it interacts with the tub by creating a strong
electro-magnet. If the stator burns out the washer won't spin or
agitate. Check the stator for continuity. This part is often
misdiagnosed.
Door or Lid Latch Assembly
If the washer won't spin or agitate the lid
switch assembly might be defective. This is a very common problem. The
lid switch assembly can fail either mechanically or electrically. Test
any electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't spin or agitate the door
lock assembly should be checked. The door lock can fail either
mechanically or electrically. Test any switches on the door lock with an
Ohm meter. The switches should have continuity according to their
design.
Motor Control Board
control board might be defective. The motor control board provides
power to the motor as well as direction and force. If the motor control
board is defective the washer may not work at all or function properly.
