Washing machine won't spin, water coming into machine ok but then just hear click sound. any suggestions
    Novelist:
  • 116 Answers
Hi, the click after filling is o.k, that's activation of water level switch, it could be faulty timer, faulty start capacitor for motor, or faulty motor, or faulty wash solenoid.
Posted on Aug 02, 2009
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
I have a top loading whirlpool washer. For some reason it stopped spinning. The water is coming in and draining I can hear the motor running but it wont spin. Any suggestions of how I can fix it without...
it sounds like the drive cupler or also known as motor cupler,,,tilt unit back and look underneath washer,,recomendid to have someone hold it so it wont fall forward on you,,then look for a plastic and rubber oreo cookie that is the cupler,,located between motor and transmission,,,second issue and a bit easyer door lid switch or safty switch,,lift cover and slowly close if you hear a click it is ok no click means no good,,,it shold click at the closed point,,if not unit beleaves door lid is always open and will not spin,,,also if unit aditates but no spin it is normally the door swich as well www.myabcspace.com/washerwizzards
May 17, 2010 | Washing Machines
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
sounds lilke a bed lid switch for safety reasons it wont spin if it thinks the lid is not closed. open nd close the lid carefully agian and again, as your doing it do you hear a clicking noise??? if not your not contacting lid switch
Feb 25, 2008 | Whirlpool LSR6334LQ Top Load Washer
Washer
Does washer spin without any clothes or water, try 'spin' only. If no, then u might have a loose connection to the motor. After u disconnect from the wall socket, see behind to see if all connections are ok. Do not over-load your machine, it could trip a switch which will stall things. Suggestions...
May 01, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
