I have a HP transparency adapter #C7671A with a small circut board inside. There's what looks like a small coil or transformer in the ceter about 1'' sq. with heat problem. #'s on it are L9107A2 and 991126 has 6 tabs on one side and 4 on other. Need to know what it is and where to get. Thanks, Brett
  • 1 more comment
  • baspas11 Aug 03, 2009
    There are 2 ceramic disk caps(marked on board C2&C3) a white box w/68n J250 on it (C1) and one small electrolitic (C4), one resistor, 2 small half drum looking things with 3 leads each (Q1&Q2)one of wich shows sings of heat on solder side of board, and one drum shaped part the same size as the electrolitic only vinyl coated 2 leads and the letter F on the side(L1)and finaly the coil discussed before (T1). I have pics, how do I post?
    Brett
    They are both the same with three legs # GC937
  • baspas11 Aug 05, 2009
    There is another number I had to use a loupe to read it, D1616 then there is a letter A below it and GC937 below that.
  • 724 Answers
Are there semi conductors on this board?
Can they be easily described?
It might be a power supply board
A transformer a bridge rectifier and a voltage regulator is there any capacitors on it?
It can be a linear power supply but since the late 80's I seen mostly switching power supplies describe that case and leads
if I find can find that other number it may be not as easy.
http://www.alldatasheet.com/view.jsp?Searchword=L9107
Posted on Aug 02, 2009
  • 1 more comment
  • tommya300
    tommya300 Aug 03, 2009
    Brett it is a switching power supply. Q1 and Q 2 has three or 4 legs on them each we need to see if there are numbers they are both the same numbers so one that has not heated should be readable...
  • tommya300
    tommya300 Aug 04, 2009
    Are you sure of the number can it be ECG 937
    You have to make sure because the nomber you gave me does not exist in any of the cross references
  • tommya300
    tommya300 Aug 08, 2009
    http://www.datasheetpro.com/193655_view_...
    Here is the site with a data sheet that is as close as I can get without seeing the circuit board and how it is layed out...
    If you feel lucky at repairing this device see if the picture matches the transistor packaged ...
    Both needs to be changed...
Thermostat is new but no 24 vac at contactor
If you are handy with meters and electrical work try this.
Somewhere there is a small transformer that supplies the 24volts.
If you trace the wires from the contactor coil back to the big circuit board then the transformer is probably on that board. Make sure you are tracing the COIL wires. If the wires go to a small transformer mounted separately then your in luck. That transformer steps down the voltage to 24 volts used as a "control" voltage for the unit. If you have 24vac output at the transformer, and no 24vac at the contactor then a control or thermostat circuit is open.
Jul 11, 2012 | American Standard Heating & Cooling
Pinout Details for HP C7671B transparency adaptor mini din connector
Cut the mini din wire, you will see four wires inside the sleeves. The red wire is positive terminal, and black wire is negative terminal. Use any 12V DC adapter to connect. The adapter will light up. Good Luck.
May 12, 2012 | HP Office Equipment & Supplies
Top mount freezer works great, refrigerator not cooling ,unit is only 5 yrs.old. I have cleaned all, coils were not dirty
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care....
Jun 28, 2011 | Haier Refrigerators
My freezer nor my refrigerator is cooling and it dosent have any ice around the coils
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Hope this help in solving the problem.....
May 08, 2011 | Frigidaire FRT18B5J Top Freezer...
Ice maker does not make enough ice
Sounds like you have a defrost problem since the freezer side is working ok . It probably is not blowing cold air into the refrig side , so to check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerato's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thruoghthe defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Aug 15, 2010 | Refrigerators
The cooling coils are icing up. Have checked the defrost element with ohm meter it seems to be good. thermostat looks to be intact and sealed. Does this mean that I have a defrost control problem?
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Aug 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Model MSD2556AEW, maytag. The fridge and freezer are not cold enough even on the highest setting.
Jun 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refg warm frezzer ok
designed function .
May 27, 2010 | Maytag MSD2756G Side by Side Refrigerator
Acer 17" LCD Turns On & Off With A Buzz Sound
not an easy fix in my opinion, power control board is faulty - relay/transformer.
I cant be certain though - look for damaged resistors/transistors.
Aug 08, 2009 | Acer AL1717 17" LCD Monitor
Side-by-side Maytag lost it's cool
Is there frost on the back wall of the freezer about 1 foot from the bottom ? If so , then a defrost problem . Either a bad adaptive timer (electronic board in control section ) , a bad bimetal (locatod on top of the freezer coils. A small cylinder with 2 wires on it ) or a bad defrost heater . Usually , the adaptive timer is the problem .
Jul 22, 2009 | Refrigerators
432 people viewed this question
jasbo
jasbo
