Question about GE DVLR223 Dryers
Dryer won't heat
I purchaced a used stackable and the person I purchaced from said it needed a heating element. How can I make sure before I order an element for $90 dollars from Sears?
    President:
  • 1,776 Answers
First, check and see if the thermal fuse is blown. It is located just inside the rear of the dryer and should be attached to the exhaust duct. It is about one inch long and can be tested using a multimeter or ohm meter for continuity. If there is no continuity, then the fuse is bad and will need replaced. While in there, you can meter the heating element in the same way. Sure hope this helped and best wishes.
Posted on Aug 02, 2009
Kenmore stackable washer/dryer. Model 417.93802209. Dryer will run but won't heat. Flipped breaker. Suggestions?
Possible that the heating element has burnt out, or that the thermostat that controls the element is defective. If you have a low or warm setting try that also as it may use a different element? Good luck.
Jan 20, 2013 | Washing Machines
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
Dryer runs but no heat. Stackable set, dryer on top.
More than likely the Thermistors are blown. They are located on the heating element canister inside the dryer, they are kinda oblong shape with two electrical connections. If you have a multimeter you can check for continuity on the thermistors and the heating element just be sure to disconnect one of the electrical connections on the thermistors and the heating element so you don't get a false meter reading, Thermistors can be purchased from most appliance repair businesses for around $30.appliancguru.jpg
Dec 10, 2010 | Frigidaire FGX831CS Top Load Stacked...
I can't find the heating element in my Frigidaire stackable dryer.
The heating element is BEHIND the dryer drum. You need to remove the drum in order to access it. Keep in mind, if you have a heat related problem, it may or may not be the heating element. It could also be the thermal cut-out (TCO) which is mounted along with the heating element. Again, you will need to remove the drum to get to it. The TCO acts as a fuse and is designed to blow to protect the heating element if it overheats. Check the TCO first to make sure it is not blown. If you need further assistance, please post back with your MODEL NUMBER. I hope this helps you.
Sep 15, 2010 | Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to www.repairclinic.com and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE DVLR223 Dryers Logo
119 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
