Question about Garden
New gas,spark,still won't start,,hole in primer bulb,would that be it
    President:
  • 1,776 Answers
Yes that is most likely the problem. The busted primer bulb should be replaced. Remove the old bulb and take it with you for comparison purposes. I got a replacement bulb at my local Ace Hardware, but alot of businesses that sell or service lawn equip should have them. Hope this helped and best wishes.
Posted on Aug 02, 2009
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Not getting gas - wont start
carburettor dirty ,primer bulb has hole in it, or at worse the inlet from the carb.to the cylinder head cracked. hope this helps
Feb 12, 2014 | Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
