Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Describe your Intermatic & Indoor/Outdoor Rain Tight Timer Problem I have the model T104 I think, stamped E10694 on it. I can set the start/stop but it does not come on, I have to manual turn on/off with the switch. I can tell if it's just worn out or can I pull the yellow piece up to see if that does anything?
Check to see if the moter is running. there is a window just above the timing wheel. If the geer is not moving the timer is not working. Now if it is and keeping the proper time. the small on off adjustable things may be the wrong model tripper. They look alike but not. there is a set with a silver and green on tripper. the Green one is for model T100 the silver is for the rest
Posted on Sep 24, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • Intermatic Expert
  • 112 Answers
Is the dial turning, or is it in the set mode, were its not engaged. if it does turn are the trippers tripping the levers. if everything is working make sure the trippers are not bent, this will keep it from engaging anything.
Posted on Aug 22, 2009
T104 intermatic stationary pointer moved to the side
T104 pointer is stationary and is supposed to be pointed straight down, assuming timer is installed in vertical position.
Move pointer until it points straight down and apply bit of super glue, or just remember correct location.
Copy following link for detailed information:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Jul 15, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
I would like to locate a manual for it
You posted under a photo that looks like Intermatic T104R outdoor 240Volt timer.
Model number usually appears inside timer door.
Add a comment if you have different timer that shown below.
Link to identify timer:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
Manual for T104
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Link below has Intermatic manuals.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Use find feature on your browser > click edit > click find > type in timer model number
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have Intermatic timer WG 1573 208/277V 60Hz 3W stamped on the case. I would like to chage this unit to a 110V timer system if possible. (In other words just be able to switch clock motors) If this is...
WG1573 is a 240 Volt clock motor for T100 series timers.
This means you have T-104 timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Image shown on link above is T104R outdoor timer.
T104 indoor timer is the same except door does not have rubber gasket.
Terminals are labeled A 1 2 3 4
If this is not your timer, then add a comment.
Following instructions will convert T104 240V timer to T103 120V timer
Clock motor can be replace with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Timer mechanism snaps out and clock motor is located on back.
Remove clock motor with star screwdriver tip
Connect new clock motor wires to DIFFERENT terminals than before.
Old clock was connected to terminals 1 and 3
New 120V clock motor is connected to terminals A and 1
Wiring for 120V T103 is shown on link below.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
White neutral wire must connect to terminal A
Black hot wire must connect to terminal 1
Dec 19, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Timer does not activate setting wheel. Stays on or off all the time.
1) If wheel is not turning, then replace motor
http://www.aplussupply.com/intermatic/timermotors.htm
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
There are numbers printed on clock motor. Also look inside door to see model number of timer. If you have a T101 or T103, T104 the T100 motor will work.
2) If manual override is not working, then replace whole timer.
3) You can buy same timer, and then swap insides
without replacing box. For example if you have T101R, the R stands for rain-tight box. Buy T101 and swap insides. Keep in mind T103 and T104 and T101 are not interchangeable due to wiring differences.
http:waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Sep 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Is the time clock rotating through the off tripper? If so, and the pump stays on, it's not wired right. Check the wiring at the clock for the pump.
Jul 01, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
871 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
