Question about Polar S150 Heart Rate Monitor
Horse trainer polar
I have a 6 yr old model, never used and now needed.  The battery is dead and Polar are not interested, they directed me to another UK site who tried to help but told me that they had no access to the rubber seals in this type of watch due to lack of seals from Polar, my local jeweller will not attempt to replace it either, can you advise re how I can replace this battery  I live near Banbridge in N. Ireland
Step 1: Remove the old battery so you can find a replacement. Somewhere should sell you the battery alone, even if they won't do the replacement for you.
Step 2: If you're not going to use this in a wet environment just put the new battery in and don't worry about the seals. Just be careful when you clean it. For example, use a damp cloth but don't immerse it.
Step 2b: If you really want to seal it get some silicon seal from a hardware store or maybe an outdoor store. Line the edge of the battery compartment where the cover meets the compartment and replace the cover. Let it set and you should be good.
Posted on Dec 19, 2007
Polar RS800: display/digits disappear when I press on start (red) button - batteries are not low, and same does not happen when I press any other button
Send into Polar, you may have a possible warranty issue, some of the older versions of this model had a glitch that was this exact problem. or for who to send into your area. This needs to be sent directly to Polar not the authorized service centers.
Apr 09, 2011 | Polar RS800 Heart Rate Running Computer...
Polar Heart Rate Monitor User Manuals
Having Trouble with your Polar Heart Rate Monitor but can't find your manual? Follow this link to download a new copy.
Don't see your Polar on the list, then your Polar is most likely over 12 years old and you will have to contact Polar directly.
USA/ Canada =
Rest of the world =
on Nov 24, 2010 | Watches
Got "memory failed" measage on
push red button for 15-25 sec
Feb 17, 2011 | Polar S-725 Wrist Watch
I cannot get the computer to register miles when I hook up the system in my garage's a cs100 polar cycle computer. It just stays at zero when I spin the wheel. I took it off my old bike where it...
The CS100 is designed to only work off the front wheel. if you are using a trainer where the rear wheel is spinning and the front wheel is stationary you will get no reliable reading. if this was the case on the old bike, you got lucky, the system is not designed to read that way. Too far a distance between sensor and computer.
If you are moving the front wheel, as on rollers, and you are not getting a signal than either the sensor and the magnet are not reading each other (too far away from each other, as an example) or the sensor has a dead battery, or you have the bike sensor turned off in your settings.
Jan 08, 2011 | Polar Cycling
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see under support in forums) link: - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Which battery do u reccommend for the polar ft80 ?
Thanks for using FixYa. You need the battery recommended by polar as replacement. You can buy it/view from this link--
Polar ft80 Replacement battery
Please do rate the solution and revert for further assistance.
Oct 05, 2009 | Polar Watches
My watch band is ripted
I don't know this watch in particular, but I know there are two main types of bands. Coded and non-coded. The S120 uses non-coded. That means you can use possibly any band on the market. Bands I know are compatible: Sigma and Ciclosport. The Polar bands are sealed, so you can use them while swimming. That's not true of the other two I mentioned - but the upside is you can replace the battery yourself once it wears down. You can probably get a replacement band from Polar directly, or buy a cheap knockoff elsewhere.
Jun 05, 2009 | Polar S120 Wrist Watch
Setting an hourly alarm on an F5 Polar heart rate monitor.
The only alarms available to use for that watch is your heart rate for exercise and a daily alarm. Unfortunately it does not have the hourly alarm feature. I wish it did I am a personal trainer and hourly chimes would help to keep me on time but my rs200 doesn't have the feature either. Sorry :)
Apr 22, 2009 | Polar Exercise & Fitness
How to change the battery on a Polar F11 Heart Monitor
Here are instructions (with images included) on how to replace the battery for a Polar F11:
Jan 11, 2009 | Polar F11 Heart Rate Monitor
Setting Polar CE0537
You do not have the right model number. For some reason, Polar puts the CE0537 in big numbers on the back of the case. The real model number on my unit was in very light engraving right above the words "Polar Electro" on the back of the case. Looks like they have an engraving problem where both the model and serial number are very hard to read. If it helps, my model was S120 and I found the manual quickly on the polar site. The polar site also has the location of model numbers in their FAQ area.
Jun 29, 2008 | Polar S150 Heart Rate Monitor
Polar S150 Heart Rate Monitor Logo
156 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
