Question about Lexmark E330 Laser Printer
More frequent paper jams are occurring in our 3 year old e230 printer. Is it time to replace or does it just need a cleaning?
  • 724 Answers
Try cleaning and replace the cart and drum device. that is all it might be. But remember by fixing things for a while, we will be sitting in the past as fast as the new future flies by our door. every 3 to 5 years is a good food for thought time frame
Posted on Aug 02, 2009
After working fine for 2 years, my Brother HL-5370 started frequently jamming and wrinkling paper.
You need to make sure your paper roller is proper working if it creating any problem then you need to check there settings then it will start working fine . Renew your printer pickup roller No more paper jams Don replace rejuvenate... Frequently Asked Questions
Feb 21, 2015 | Brother Office Equipment & Supplies
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper Jam
hi...
1)After years of heavy use the rubber rollers which transport the paper through the printer can get a shine to them and tend to loose their grip. This causes misfeeds and blockages.
Using a damp cloth and something like Jif (slightly abrasive kitchen/bathroom cleaner) rub the rollers whilst rotating them by hand. With a clean damp cloth remove any cleaner and you should see the rubber has lost it's sheen.
Some rollers can be hard to get at but a little patience pays off. I've reclaimed dozens of printers due to be scrapped in this way.
You can also try turning the printer upside down and softly tapping it. You could be surprised at what drops out. My best to date was pieces of an illegal plant substance and a rare Chinese coin. (Yes it was returned to the owner :-)
or
2)The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. (images 1 to 2)
7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. (Image 3)
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
thank you
Jul 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Frequent paper jams.
hi im josh in cebu phils. may i help you? friend if the problem still occurs even though it was already repaired. there is a hardware problem involve possible the paper feeder roller.try to remove it and clean it first so that you can economized the cost.but if it still occur you need to change that already so that you can use the printer. good luck friend.
Feb 27, 2009 | HP LaserJet 1300 Printer
HP LaserJet 5000n - Paper jam under the cartridge
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Jan 03, 2009 | HP LaserJet 5000n Printer
Paper jam is showing on printer info., but ther's no paper jam.
Ok this issue ussually occurs when the roller feed doesn't load the paper due to the following reasons:
1. If your printer is operating for  more than two years or so... gear tear will most likely to occur. If you can open the printer and check everytime the printer initiates after power on ad if the roller feed doesn't rotate but the leftmost rotary gear with the encoder wheel rotates, the gear is most likely to be loose even there is no paper jam nor dust contamination on the rubber and paper feed mechanism. You need to replace the said gear with the encoder strip . A simple solution would be aplying epoxy resin so it will be fixed on the rotary shaft. It may last for quite sometime but better yet replace the gear.
2. The feeder rollers might be dirty and needs to be cleaned and greased the gears.
3. Probable defective print cartridge. Try replacing it with a new one.
But based on the items above, if your printer is operating more than a year or two, and frequent paper jam is being experienced, gear tear near the motor is the culprit.
Dec 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jams on the right hand sideon the last half of the sheet. the printer is clear of all paper from previous jams. The printer is an Ofice jet 6310 All-in-one
If it jams all the time, then there is a problem with the mechanic paper feed gears.
If it is an occasional paper jam, just remove the paper and restart the printer.
Give me more details for more troubleshooting.
Oct 08, 2008 | HP Office Equipment & Supplies
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Lexmark E330 Laser Printer Logo
147 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
