Question about Craftsman 25cc Gas Line Trimmer
Where can I get a replacement filter for the gas tank
    President:
  • 1,776 Answers
You should be able to pick up a replacement filter at WalMart, a hardware store, or most any place that sells or services lawn equipment. Take the filter with you for comparison purposes. Hope this helped and best wishes.
Posted on Aug 02, 2009
How to replace fuel filter 08 r1
Take the seat off of the bike ,then take the tank loose and gently lift up on the tank ,turn the pet cocktail valve to the off position turning off the gas flow then remove the gas line from the tank and remove the 2 small vent hoses from the tank and set the tank off on the ground.directly under the tank is your fuel pump the line going fro,m the pump to the throttle bodies has a clear capsule shaped filter in it pack a rag under it too catch the gas loosen the clamps and remove the lines from the filter and put the new filter in the same way you removed the old one and reassemble the bike hooking the vent hoses back to the tank and the fuel line turn the gas valve back to the on position and bolt the tank and seat back down and your filter is changed
Apr 28, 2014 | 2007 Yamaha YZF-R1
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
My daughters rodeo wouldnt start. Battery is brand new, sounded like it wasnt getting gas. Fuel filter was just black, it has been changed. Truck still wont start. Any ideas?
check the tank is it plastic... if so drop the tank pour gas in bucket if black stuff in the gas take a water hose and spray it out wait till dry put it back on and put gas and try to start it,,, if fuel pump in tank replace it... please let me know how it turns out,,, good luck
Jan 28, 2012 | 1995 Isuzu Rodeo
Were is the fuel filter and is the fuel pump in the gas tank
the fuel pump is in the gas tank and the fule filter runs along the bottom of the Driver side..if your looking at the gas tank follow the gas lines that go toward Eng. you will see the Fuel filter
Dec 30, 2010 | 1996 Dodge Caravan
Had water in the fuel filter replaced it and now it tries to die if I'm at a red light
add two cans of Heat gas treatment to it with a full tank of gas to eliminate the moister that is left in the fuel system
Jun 27, 2010 | 1999 Buick Regal
I have a 1989 Bronco 2 and it is not getting the fuel right. I think it is the fuel pump. Does anyone think what else it would be. I already replaced the filter. How would I replace the fuel pump?
The fuel pump is in the tank. Drop the gas tank.
1. Support the gas tank with a jack or something
2. unbolt the gas tank straps
3. unscrew the rubber filler neck going to gas tank
4. Lower gas tank slowly and disconnect gas lines
5. Turn the retainer ring that holds the fuel pump in the tank and left out.
6. Drain gas into gas cans to make the gas tank easier to left
7. Replace fuel pump and reinstall gas tank.
Feb 08, 2010 | 1989 Ford Bronco II
Gas in tank wont start unless put gas in carb-then
Hi, being a tiller theres a good possiblity that the line is glogged and if theres a line filter it could be plugged also. Another source of clogging is from old gas, ti can become a little varnished.
Remove the line clear it with compressed air or other source, drain the tank and if theres a line filter - replace it.
Another source could be the air filter - usually a sponge. Replace this as well or clean in a varsol bath. squeeze it out dry, then apply some oil to the input side - helps to catch dirt, etc.
USE safety precautions .
dont forget to vote
Oct 14, 2009 | Garden
How do I get to the fuel filter in the gas tank.
I have never seen a fuel filter in the gas tank, fuel pump yes. To get to anything in the tank the tank has to be removed from the vehicle.
May 19, 2009 | 2003 Land Rover Range Rover
Craftsman- gas not flowwing to engine from tank under seat.
Yes there is a filter in tank but cant be removed,dump gas out of tank and leave gas cap off place a rag over tank to catch any gas that you couldnt remove doesnt blow all over then take your air hose and blow through the gas line this will clean the filter after you do this place a can under gas line to catch gas and put a little gas in the tank to see if your problem is solved .
May 09, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
1988 gmc v 3500 350m carbuerator
its possible that there was something in the tank or line that plugged your new filter. try changing it again
Oct 10, 2008 | 1988 GMC K3500
Craftsman 25cc Gas Line Trimmer Logo
151 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
