My scroll button will only move the screen up but not down. My numbers pad is inactive and my Mac keyboard does not have a "numbers lock" key. Help!
  • 9 more comments
  • rontredding Aug 02, 2009
    disconnecting the usb connection for the mouse to the keyboard does not change anything. Restarting the computer also has no effet.
    On a iMac one doesn't use any button other than rolling the scroll up or down.
  • rontredding Aug 03, 2009
    Sorry, the Universal Access mouse key was set to Off, so still no solution
    Universal Access mouse key is already set to off, but still having a problem scrolling down and the #s pad still inactive.
    Scroll button on the mouse is active only on up, not down. Have to manually use the buttons or side bar. Numbers pad now activated
    Wireless Mighty Mouse scroll button has the same problem: scroll button on the mouse only moves up, not down. 360 degree option is chosen in preferences.
    Clear buttons works on #s pad, but mouse scroll button still only goes up not down.
    Latest version of iMac with Apple keyboard and mouse.
    Doesn't appear to be anything interfering with the mouse scroll button. Just doesn't want to scroll down, only up. Scroll button is set for 360 degree usability.
  • rontredding Aug 04, 2009
    I've cleared up the #s pad problem. My iMac mouse still does not scroll down, only up and I still need a solution to the scroll button problem.
    #10 was the charm. Thank you so much.
    President:
  • 2,185 Answers
Have you tried cleaning the ball?
Turn mouse upside down. Get some cleaning fluid or alcohol and use a soft cloth dabbed with it and rub the ball allowing it to turn.
That should clean it.
Posted on Aug 04, 2009
    President:
  • 2,923 Answers
In Mac, the Clear button on the keyboard is the "Number Lock" key. Press the Clear key once and try using the number pad. It that didn't do anything, you need to contact the manufacturer of the keyboard for repair.
By the way, are you using a power book? If yes, I could see that the touch pad is bad and needs repair.
  • 116 Answers
For the scrolling, try to turn the mouse upside down and shake it a little bit. It might be a little chunk of something that is stuck there. Just experiment a little with the scroll wheel.
The numbers pad problem: Try going to system preferences - universal access - under the mouse tab. Make sure that Mouse Keys is set to "off"
Posted on Aug 03, 2009
  • Vebj?rn Bjerke
    Vebj?rn Bjerke Aug 03, 2009
    Have you pushed the clear button?
    Sergeant:
    Novelist:
  • 198 Answers
What is the model of your computer?
Are you using a Mac keyboard on a PC (Windows machine)?
  • 601 Answers
Hi....
Use the Clear button for Num Lock.
Let me know.
Thanks
Smith
    Brigadier General:
  • 3,614 Answers
Better to try check it first using a different mouse, to check if there was no problem on the mouse you use. Restart your computer and see if there was changes.
Hope this helps
  • 339 Answers
The "Clear" button works like Num Lock. Unfortunately there is no visual feedback on the keyboard to let you know if it is selected or not.
As for the scroll button, I assume you are talking about the up and down arrow keys? If so, the issue may be that scoll lock has been turned on accidentally. Try hitting F15 once and see if that helps.
  • 10,515 Answers
Apple menu>system preferences>universal access>mouse. By accident I found this (mouse keys box) was clicked ON! This disables the keyboard almost completely. it is so remote from the other keyboard controls that it is not the obvious cause.
If problem still persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Hi there
When you press the Scroll button, what button do you use to move the screen upward?
Posted on Aug 02, 2009
  • 11,896 Answers
This is a hardware problem. You can double check that the keyboard is enabled and that all drivers are downloaded for it.
Quite likely, disconnecting and reconnecting the keyboard will fix this. If not you will have to replace the keyboard. In the meantime, have you tried an external keyboard?
I have a Mac computer and the key board Num Lock won't turn off. I tried Fn=Shift+NumLock or Fn=NumLock but still won't unlock, Help
Hi Kip,
On the right side of the number keypad on a Mac Laptop, there is a 'Clear' button above the number 7. Press Shift + Clear to turn Num Lock on. Press that again to turn it off. If the keyboard doesn't have a number pad, press F6.
Apr 11, 2014 | IBM Thinkpad 560 Series Laptop 20h4241...
My mac screen and wallpaper moves every time I touch my mouse
I think what has been done is your grandchild has accidently magnified your screen slightly. To correct this hold down your ctrl key on your keyboard and move your finger on the mouse scroll button back. Hope this helps.
Dec 16, 2011 | Apple 20" iMac Desktop
How to stop my G4 Mac desktop screen from jumping around when mousing? My screen moves left and right, or up and down when mousing around.
I think what you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key on your keyboard and move your finger on the mouse scroll button back. Hope this helps.
Aug 04, 2011 | Apple iMac G4 Desktop
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
#s pad inactive & mouse scrolls up, not down?
Try forcing the scroll wheel up and down and pressing it in...... It is jammed in some way right now....... Happened to me too!
Aug 02, 2009 | Apple Power Mac G5 Desktop
Number pad on iMac keyboard inactive
Press "clear" on the numbers pad, then the numbers will type.
Jul 28, 2008 | Apple Power Mac G5 Desktop
Scroll Lock on -- mystery
On the Logitech LX710 Lazer the Scroll Lock option is toggled by holding down the "Function" key and pressing the "Pause/Break" key. If you look at the P/B key you will see a little orange symbol of an arrow pointing down to remind you of this feature. This can be disabled in the Setpoint panel by selecting Keyboard and Keyboard Inactive Keys then place a check in Disable Scroll Lock so you may have to remove a check mark first.
Jun 25, 2008 | Logitech LX 710 Keyboard/Mouse
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
