Gateway 6510GZ LCD backlight goes out
Gateway 6510GZ LCD backlight goes ou. it stays on for 4-5 minutes, then the backlight goes off. I have tried all sort of power setting options, inc. the one in the BIOS called AUTODIM when on battery only.
BIOS is 61.01
I have tried another inverter that didn't help. IF I connect a second monitor then toggle between them with the Function F4 , the LCD comes back on.
  • super_pcc Aug 02, 2009
    I have replaced the LCD invereter but have not tried to replace the backlight bulb. The inverter I used was a good pull according to the seller. I understand that replacing the backlight bulb can be a complex undertaking.
  • Bill Haughee
    Bill Haughee May 11, 2010
    so, you've installed another backlight power inverter? Have you replaced the backlight bulb?
  • 17 Answers
Depends on your comfort - but if you've been as far as the inverter I would think not. The bulb usually runs on the bottom of the display and our vendor provides good step by step instuctions.
Posted on Aug 03, 2009
6510GZ PC Notebook: gateway ml6232 want power up no lights...
Can be a lot of things.
Try with removing battery for 10s.
If that doesn't work, access RAM, remove it and install it again.
May 18, 2010 | Gateway 6510GZ Notebook
Power stays on but screen goes black on my Gateway laptop.
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
MY Gateway notebook 6510gz is always dyeing on me
You don't need a recovery cd. You just need to remove the hard drive and insert it into an external drive caddy. Then it will become just like an external hard drive. You can browse the drive to copy over your new files and then use the drive for backing up your new files in the future.
May 11, 2009 | Gateway 6510GZ Notebook
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Laptop locked up while watching a dvd
Well I'm glad everything worked out.
So you just pried the DVD tray open with a paper clip and it opened releasing the DVD and computer worked again?
I'll have to try and remember that hahaha
Hope you have a great week too ^_^
Apr 19, 2009 | Gateway 6510GZ Notebook
LDC Screen
Search eBay for Gateway LCD backlight
Oct 11, 2008 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
