Question about Kenmore Refrigerators
Automatic ice maker won't make ice
The tray doesn't fill up with water. We first thought maybe the line was frozen so we turned it off and let it thaw but that did not fix the problem. We are wondering about pressure? We recently bought a new filter and the ice maker stopped working about a week or so later. The door water dispenser still works fine. We also pulled the refrigerator out from the wall to check for a kink in the line but that appears to be fine. Thanks.
    New Friend:
  • 63 Answers
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Posted on Aug 02, 2009
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
The front egde of the ice maker overflows into tray and causes big ice block in tray.
Start with changing the water valve in back of box. Take the water line from the valve and blow in to line to see if fill tube is frozen also. If it is take a hairdryer and thaw the fill tube. Turn off the box while thawing tube then turn on. If all this dont fix it time for new maker. But dont replace icemaker till you check the rest because It wont work if the tube is frozen or bad water valve. I hope this helps.
Aug 29, 2011 | Refrigerators
My model is 596-50699001 and the problem is does't do ice, and change a filter what can I do to fix it ? Thankyou for helpingg me
There three problem that will not make your ice maker to make ice.
If the water’s route is blocked or the solenoid doesn’t work
If the bail wire is lifted—the ice maker won’t make ice.
Your home’s water pressure must be strong enough to serve an ice maker.
For your ice maker to maker ice,
be sure the bail wire above the ice tray is in the down position.
If the ice maker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
Also,check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
The water line attaches to a solenoid at the back of the refrigerator and then travels to the ice maker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first.
Check the tap valve; a bad tap valve may cause the problem where the ice maker supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Thanks for contacting Fixya.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Refrigerators Logo
195 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
