Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Just bought and assembled today. Plugged and and
Just bought and assembled today. Plugged and and have a "paper jam" message saying to open carriage door and clear jam. I do not see a jam. Not possitive what the carriage door is.
  • 326 Answers
Assure that all the shipping tabs have been removed from the cartridges and any others. They will be listed in the guide provided with the device that will probably fold out into a poster.
Assure that there is paper in the device.
Assure that there is an adequate amount of paper in the paper tray (>25 sheets).
Assure all paper paths are completely clear of paper, scraps, and debris. (Including dust, utilize a can of compressed air or similar method)
If all of these have been checked they you may have to assume the device was damaged during shipping or D.O.A. software wise. These devices have both physical and digital sensors and checks for paper paths. If these errors persist after a user accessible cleaning and the use of canned air, the device is most likely damaged.
Let us know
Thank you for choosing FixYa!
Posted on Aug 02, 2009
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
