FixYa.com
Tags:
Paradyne ADSL/R 6381 Router
Cannot access my modems home page.
posted by hd90flstf on Nov 25, 2007
I cannot access my Paradyne 6381-A2-200 modem's home page. I have tried entering the http://192.168.1.1 address but it says not found in my webpage. I can still access the internet but cannot configure my modem. Please help. Thanks in advance.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 26, 2007
Helpful (85)
MilT0N
Rank:Guide Guide
Rating: 90%, 6 votes
Nore than likley that is the default LAN IP address that came with the device. It has probably been changed during the initial setup. A quick way to tell is go to your start button/ select run / type in the run box CMD / this brings up a dos shell in the dos window type IPCONFIG and hit enter.. Note your IP address and your default gateway.. " the default gateway is your device in question. make sure your IP address matches your gateay with the exception of the last 3 octects. so it should read something like this
IP Address 192.168.1.50
Subnet mask 255.255.255.0
Gateway 192.168.1.1
My guess is that your not on the "1" network but the router is handing out a different range of address if that is the case in the dos window type ping (the ip address of your default gateway)
like so ping 192.168.X.X where X = the octet values of the default gateway listed in the dos window
If it replies then your talking just fine you are simply trying to access your router via the wrong IP so take the IP of the gateway listed from the ipconfig command and put that number in your browser.
If this is not the case then we need to go in a different direction with this.
MilToN
CNA,CNE,MCSE,CCNA,Network +
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Routers problems?
Routers
Belkin Firewall interfers with...
How do I configure my belkin... Answer This...
Routers
360 mtu test keeps failing
360 says mtu failed how do i... Answer This...
Routers
I want to setup a wireless...
I would like to implement ip... Answer This...
Routers
Cannot connect with SonicWall ...
I can connect all my... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
