Question about Motorola Mobility Moto Q
Flash Mode my q turned off when i had full battery and wont turn on unless it is plugged into the charger. when i get it turned on the screen is back and the message motorola flash mode bootloader version: boot_c_03.05.00r_mpap usb cable connected comes up what can i do
  • BB4RN Dec 05, 2007
    My Motorola Moto Q was charged and i tried to turn it on. The black screen appeared with Boot...... please plug USB cable in . After plugging it in it said USB plugged but my computer didn't read the phone. I took the phone to sprint and am now waiting on them to replace or fix it.
  • 46 Answers
Sounds like your device is defective and needs to be replaced. Time to look for your warranty info sorry to say
Posted on Nov 25, 2007
The screen turned off and it wont turn back on!!!
The symptom you described may be due to the main battery being discharged. In many tablets, there are 2 batteries, one main and one used to keep memory intact during suspend mode. When the unit powers on, it turns on the backlight (probably the highest power drain of anything on the tablet) so you can see the icons on the screen. If the main battery doesn't have enough energy, the sense logic will put the machine back into suspend mode, and it will appear to go off. You should plug your charger in, and see if this fixes the problem. If it doesn't then you need to check the voltage of the charger with a meter. If you don't have a meter, you can buy then at Harbor Freight for around $5. With the meter on, and the charger plugged in, stick the red lead of the meter in the center hole, and touch the black lead to the barrel of the power connector from the charger, and you should read some volts. The charger should say on it somewhere it's output voltage. Hopefully you've marked your charger with what device it goes to because many chargers look the same and have the same power connector but are not in fact the same.
Making the screen brighter uses more energy. So if you were successful with your "sun" icon, you could have made the problem worse.
Nov 27, 2017 | Google Android 4.0 7 inch 1080P Video...
My camera is a vivitar pink (MID0050609) and it wont turn on, unless i plug it it to my charger and when i do the light on the left is red and it just blinks then flash a blue screen turns on that says...
MSDC is not a problem code. It is normal, the camera is informing you that it's connected to a computer. At this point you should see a new "drive" show up in my computer to transfer pictures.
Have you tried turning the camera on when plugged into a wall charger? If it turns on using the wall charger it might need a charge over night. If the camera will still not turn on after a charge the battery is dead and needs to be replaced.
Mar 12, 2011 | Cameras
Motorola flash Mode Help...
simply change the motherboard it will work good
Sep 15, 2008 | Motorola Mobility L6 Cellular Phone
E260 Wont Turn On
on the desktop click right button and click go to the apperance below the windows and buttons chane it as windowsxp style.
Jun 14, 2008 | SanDisk Sansa e260 MP3 Player
Motorola Flash Mode
Can you hold down the center nav key and power up the unit? Then select Yes and perform a Master Reset on the unit. This should fix the file system possibly correcting the issue.
Is this a Q, Q9m, Q9c, or Q9h? Who is the carrier?
Dec 02, 2007 | Motorola Mobility Moto Q
Motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
Sep 16, 2007 | Motorola Mobility Moto Q
Wont play unless it is plugged in
Hi, I would suggest that the Battery is faulty.. a common occurrence I have found... Try a brand new or fresh charged know good battery.. I think ya may find thats the culprit.. Also check & clean the Batt Cons inside the unit.
Aug 04, 2007 | RCA Lyra RD2840 MP3 Player
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
155 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
