Question about The Computers & Internet
I have applied last year27/10/2017 for ADSL. I phone Telkom, they said that my order is not jet updated they say that I must phone Open Serve. Open Serve said it is updated.My Order number is 357907.
The line is routed from the connecting point to my house, it just needs to be connected and my router or modem needs to be installed. Then I have ADSL, when will this be resolved?
  • The Master
  • 9,777 Answers
Contact Telkom, but expect you may be talking to contractor operated response employees first, and need to be patient with this company, which inspires many questions to FIXYA. FIXYA has no relationship with Telkom, and is not located in the country of South Africa. Please understand that FIXYA has unpaid volunteers and a large volume of questions that cannot possibly be answered without details and information that questioners repeatedly forget to provide when typing on a cell phone. FIXYA does not offer online chat, and volunteers will not call your phone. 6YA is not free, and it a paid service if that is relevant.
Telkom web sites abound:
https://secure.telkom.co.za/today/help/personal/faq/when-it-best-contact-telkom-customer-care-call-centre/
Get Help Telkom
Posted on Jul 31, 2018
    Top Expert:
  • The Master
  • 29,841 Answers
How would we know! Contact your provider for an update.
Testimonial: "How can I contact them if there is no one answer the phone. I thought that you will be able to assist me, to try and see what is the hold up is with my order. And then to take it up with them."
  • JonSnell Electronic
    JonSnell Electronic Jul 31, 2018
    Your problem is not a computer/internet technical issue. This is a technical forum. We are not affiliated with any company. Email them.
SOURCE:
Mtnhorse
SOURCE: Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Posted on Aug 18, 2007
patemi
  • 366 Answers
SOURCE: Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Posted on Feb 09, 2009
rahul26485
  • 611 Answers
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Posted on Apr 04, 2009
yboyandrei
  • 828 Answers
SOURCE: connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Posted on Jun 16, 2009
shademand
  • 114 Answers
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Posted on Sep 06, 2011
My house computer is being fixed out of the house, now my wireless computer isnt working, i have to connect to the phone connection. Is that the way it should be?
Check All your connection Reset your Router in the back you will see a little hole with a button press on it for 10sec.. Then got in your Sitting Control Pannel add and Remove ...Remove your Belkin software and re start your PC then re install your belking software for Any PC You may have a 4 hub conection ... So make shure your Modem are connected on the right Hub on your Router and the phone line to the modem Because See The modem tranmit is data to the router the transmit on any pc connected ony your Router ...good luck
Sep 22, 2010 | Belkin (F5D7231-4) Wireless Router
Does a wireless router need to be connected to a phone line?
Hello emanuelav716, Your router does not need to be connected to a phone line. However is does need to be connected to a cable or DSL modem if you want internet access. If you are just looking for a network inside your home or business the router can be setup that way. Please reply with any other questions or rate this solution if you found it helpful. Thanks! Edward
Aug 22, 2010 | D-Link 802.11g Wireless Router WBR-1310...
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
I have moved one of my two computers to my guest house which is about 120 feet away from my cable modem and I have no connection to the internet. I have the computer in the main house connected to a...
I would go wireless. Try to connect to the net using a laptop (wireless) at the guest house. If the signal strength is decent you should be fine with getting a wireless NIC for the PC in the guest house.
If the signal strength is bad, either buy a 802.11N router (make sure it's N and not draft N, these should be available now or within a few weeks (nov 09), or buy another access point and connect it via ethernet to the main access point. you only want one modem and one gateway generally speaking.
Nov 08, 2009 | NetGear WGR614 Wireless Router
Wireless to my laptop
Hi there.
You can buy just 1 device nowadays a wireless modem router, this will connect directly to the cable or telephone socket and give wireless access almost straight away.
May 28, 2009 | Gateway M305CRV Notebook
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Installing acces point
Yes, you can chain routers together if you'd like, however people who connect to the first router connected to the modem will not be able to see the people connected to the chained router. However, people connected to the chained router will be able to see the other people connected to the main router.
Steven
Jan 07, 2009 | Computers & Internet
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
103 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
