Question about Yamaha 12V Air Pump
1991 Yamaha Waverunner WRB 650 Will idle but will not take fuel.
I put a clear line on from fuel filter to carburetor and it flows good. The choke is not stuck.The high speed screw is at 1.5 Both jets are clean.The fuel filters are clean.
  • rsrbob May 11, 2010
    What problem are you trying to resolve?
  • Roscoe007 May 11, 2010
    Not sure what your topic is it looks like it was cut off,at the title.
vortash
  • 431 Answers
SOURCE: Yamaha 660 raptor dies when choke is tuned off
hello I am Vortash .. I would say your problem is either blocked idler jets or incorrect fuel mixture ( Air to fuel not correct ) take the bike to your local garage to use their air line unless you have a compressor of your own remove the fuel feed tank side and blow it through with the airline if this don't cure it you will probably need to have the carbs tuned to manufacturesr spec's , If you are more mechanicaly minded strip the idler jets out pass a fine strip of wire through them and replace .You can also get this problem if you have an air leak on the maniflod or the carb bowl etc hope this helps regards Vortash
Posted on May 14, 2009
  • 12 Answers
SOURCE: Yamaha 06' V-star 650 idle prolbem!
Fuel filter is located near the fuel shutoff valve within three inches. It is inline between the shutoff valve and the fuel pump (towards tank).
The fuel circuit is: Tank/Fuel Pump/Fuel Filter/Fuel Shut-off Valve/Carbs.
You first step is to check for fuel delivery to the filter. Make sure the bike is cool and no iginition sources are nearby. Disconnect the inlet line at the filter and turn key on and crank engine (to trigger fuel pump.) Do not try and start at this time (choke off).
If fuel is adequate to the filter, check the filter by blowing through it, it should easily pass air. Replace filter if questionable.
Next reconnect the fuel lines and remove float bowl drain plugs in the back of the carbs (2 per carb). If with key on and cranking fuel pours out of these ports then you probably have clogged fuel jets. If not then the float bowl needles / pipes could be plugged with varnish from dried fuel. You can try spraying carb cleaner into the fuel inlet to clear the varnish and then retest. Careful not to spray carb cleaner on yourself (wrap straw with a rag).
If you have good fuel flow to the carbs and bowls you probably have varnish plugging the jets. You should remove the carbs and clean them thoroughly.
Hope this helps,
Kal
Posted on May 18, 2009
  • 9 Answers
SOURCE: won't idle steadily
Check the rubber boot that joins the carby to the engine to often have seen the hose clamps over tightened therefore creating a split in the rubber letting to much air in giving the rough idle eventually you wont be able to start it at all (have a good thorough look inside an outside of boot doesnt take much)
Posted on May 22, 2009
finish line
  • 207 Answers
SOURCE: My 2005 Yamaha FX HO Waverunner runs smoothly, but
yes yes yes the new yamahas foul plugs like crazy i dont know if it is a valve defect or what but you will be changing them every year one trick i have been doing to my coustmers watercraft and has been working well insead of ngk cr9eb plugs use a cr8eb it is a hotter plug there for it will burn better and no it will not hurt your ski trust me i have over 15 yrs ex and 6 in r&d research and design
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
2002 Yamaha V Star 650 only runs with choke on
Hi, John and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Total Motorcycle Forums
Bike won Run without Choke
Yamaha XVS650 Service Manual
OEM parts for Yamaha
YAMAHA XVS650 Owner Manual
Aug 27, 2017 | 2002 Yamaha XVS 650 Dragstar
Carburetor
Hi, Anonymous and the usual suspects are:
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
yamaha yz125 Choke for carburetor Google Search
Yamaha yz125 look over and carb help
Yamaha YZ125N1 Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 27, 2014 | Yamaha YZ 125 Motorcycles
2004 Vstar 650 only runs with full choke, dies with throttle or pushing in the choke, I plan on changing the fuel filter tomorrow. I also found a small ball bearing in the tank, should that be there?
Hi, Anonymous not sure about the ball bearing talk to your dealer and the usual suspects are:
2004 Vstar idle only on full choke problem
http://forums.cycleworld.com/showthread.php?t=169267
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Aug 19, 2012 | 2004 Yamaha V Star Classic
2000 Yamaha WR400 wont run with choke off.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
WR400 won idle choke
Help 2000 wr400 won idle off choke What could it be motorcycles
YAMAHA WR426F Owner Service Manual
YAMAHA WR450F Owner Manual
May 19, 2012 | 2000 Yamaha WR 400 F
I have a 1980 yamaha xs 1100 special, it sat in a garage for 3 years, i replaced the fuel lines, cleaned the tank, and replaced the plugs, how come it only idles when the choke is on and it sounds like a...
You probably have varnish build up in the carburetors, causing restricted air flow, and therefore the engine is running too lean, especially on the right side, and a lean running engine will run hot at the exhaust. It only idles when the choke is on because the choke creates a richer fuel supply. A can or two of commercial fuel cleaner through the fuel supply may get the engine's jet's orifices cleaned out. Otherwise, overhaul the carbs.
Hey, nice old bike, though. Good luck
May 20, 2011 | 1979 Yamaha XS 650 F
Hi, my yamaha maxim 650 will start but will not idle off choke or stay running off it or when i give it alot of gas. could it be the petcock? or the throttle adjustment screw?
Hi, Alexmacy and the usual suspects are:
Yamaha XJ650 Idle Problem
1982 Maxim xj650 idle issues
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
https://dd5394a0b8ca8e97ba29-abf76f3d91a2125517d6c7c409f095c7.ssl.cf1.rackcdn.com/content/common/manuals/1999/LIT-11626-12-30_126.pdf
May 16, 2011 | 1981 Yamaha XJ 650
I have a yamaha 650 v-star classic won't stay running with choke in.
Hi, C60stillions and the usual suspects are:
Yamaha Star Carburator Cleaning
Mar 31, 2011 | 2003 Yamaha V Star Classic
My 2005 V-star 650 will only run with the choke out and stops running when pushed in. Adjusted idle and still no change. What could be causing the problem.
Hi, Iam3of6 and the usual suspects are:
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Sep 18, 2010 | Yamaha V Star Classic 650 Motorcycles
650 yamaha vstar 2006 stalls out when giving it gas
Hi, Donjkiii and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
650 idles on choke and dies on throttle in 650 Star Tech Forum
http://www.starbikeforums.com/forums/49-v-star/68346-650-starts-but-dies-throttle.html
Sep 07, 2010 | 2006 Yamaha XVS 650 Dragstar Classic
Yamaha 12V Air Pump Logo
527 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
