Question about Panasonic Viera TH-50PX80U Plasma TV
Cannot change input source for tv by button on front of tv..seems all the buttons on the tv are not responding. Remote will not change input source either. Trying to get the dvd playing, tv just started doing this. It is a th-50px60u....this is the model. Did not have the model choice on this screen only the 80u would come up.
  • 476 Answers
I would try the abvious first, unplugg the tv from the ac outlet and wait for a few seconds then try turning tv on see if the problem is solved, if not it might be that the key board panel needs replacing.
Posted on Aug 02, 2009
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
May 12, 2012 | Sony Televison & Video
Where do i find thr AV setting on my tv set?
If you mean changing the input source to AV, it depends on the brand and model. Some units have an Input or Source button on the front panel (or side panel) of the TV and on the original remote. Other models only have this button on the remote.
If you are interested in a replacement remote for a unit that only has the Input button on the remote, try a searching for the model on remotes.com . Alternatively, look for a universal remote that is newer than the TV with an Input or Source button. Then try all the codes for the brand until you find the one that makes all of the features of the remote work.
If you are interested in the signal information (resolution, for example) of the content on the AV source, try the Info button on the remote (if available). To adjust the setting enter the Menu (either from the button on the remote or the TV panel (if available) and look for the Picture submenu.
I hope this helps. If you provide the make and model of the TV, I may be able to provide more information.
Mar 21, 2011 | Televison & Video
Where do i find INPUT SELECTon zenith tv sy2779dt,trying to hook up Wii and default Wii screen does not come up. manual says to change IS. don't have orig remote, only dish 500.is there a way to change IS...
Most tv's have a physical button on the front and it will either be labeled input or source-source select. If thats not the case on your tv, look for a menu button and try to navigate through the tv menus until you find tv input or source select. If that still does not work, you can use your dish 500 remote and if you already use that to turn the tv on and adjust volume, you can probably use it to change the input. To do this, select the tv mode on your dish 500 remote, and then press the source or input button until you get to where you need to be. Once thats done, make sure you return your remote to sat mode or you will not be able to control the dish reciever. Hope this was helpfull to you.
Thanks
Jan 03, 2011 | Zenith SY2765S TV
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Dec 29, 2010 | RCA 32V524T TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Panasonic Viera TH-50PX80U Plasma TV Logo
1,323 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
