Question about Kenwood VR-407 Receiver
Shuts down at high volume
When watching DVDs with volume set relatively high (in the 30 range), the kenwood vR407 tuner system shuts down when there is a loud volume output from the movie. Any suggestions? thanks alan
  • Anonymous May 24, 2008
    We're having the same exact thing happen. But, ours isn't even in an enclosed unit......Could it be speaker wires not hooked up correctly?
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Posted on Dec 10, 2007
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
Kenwood kdc-mp142 why does it shut down when
Have you checked your speaker wiring as it could be you have some wires crossed ie: negative feeding the positive side causing the shut down & check the Ohms if at high volume you are trying to drag to many Ohms it will also cause the built in amp to shut down to protect the system dont keep incresing the volume as the strain will do damage
Sep 18, 2014 | Car Audio & Video
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Amp cuts out and back on 30 or so seconds!! Volume has no impact
You need to check the B+ and remote voltage on the amp when it cuts off (assuming that you can recreate the fault).
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
Nov 29, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KDC-MP3035
make sure you have 12 volts into the radio at high volumes mine shuts off when i turn it up over 25 due to power draw
Nov 18, 2007 | Kenwood KDC-MP3035 CD Player
Receiver Shutoff
That may be a clue to your shutdown problem. Disconnect that speaker and see if the unit still shuts down. If it does not, then there is a problem with this speaker,or the wiring going to this speaker. If the unit still shuts down, disconnect each speaker at a time to see where the problem is. If none of the speakers seem to cause the shutdown problem, there is na major fauly in the amp circuit, so the amp will need serviceing or replacement. Good Luck
Apr 08, 2007 | Kenwood VR-4090 Receiver
Volume turned up, kenwood shuts off briefly...
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
Kenwood VR-407 Receiver Logo
227 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
