Question about RCA 25423RE1 Phone
Can not get a dialtone to call out and when my other house phones ring and I pick up the receiver on the RCA, no one is there.
  • RCA Master
  • 5,266 Answers
Move a known good phone to this jack and plug it in. Similarly, take the phone to another jack that you know is working. (Try new phone cords on the non-working phone.) If you get a dial tone with this phone at another jack and the wire is good and seated properly at the jack and the phone, you'll need to take a closer look at the jack. A wire might have come loose in the faceplate connections or keystone jack. If you have a keystone jack, reseating the wires requires a "Punch down" tool to push down the wire. Replacement jacks (at hardware or tech stores) come with a plastic one included. Better ones are sold separately. If the phone doesn't work at another location, check your manual and warranty information.
I hope this helps.
Posted on Aug 02, 2009
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
Instructions for uniden FP1200 phone
I have a Uniden FP1200 LCD Display Caller ID Speaker Phone
I have no dialtone and when you pick up the receiver the time begins to count as if I am on a call
Thanks
Karen
Apr 20, 2013 | Lands Phones
Phone shows a voice mail but no message on phone
The phone's voice mail indicator works with the voice mail function from your phone service provider. When your line is busy or goes unanswered (depending on how it's set up), the message is recorded by your service provider at their end, and you need to retrieve it. Most systems give a "stutter dialtone" when you pick up the phone to make a call (a few short bursts of dialtone before it becomes steady) to tell you when there's a waiting message. The message waiting light on the phone lets you know in case you don't pick the phone often.
Once you pick up your voice mail the light will go out and the dialtone will go back to normal. Check with your service provider for how to do it.
May 25, 2011 | Lands Phones
We have a Merlin System, the phones are MLX-10D, we have to dial outgoing calls 3-4 times before the call will go through. Now we're receiving complaints that incoming calls are just ringing and we don't...
Sounds like one (or more) of your lines are out in your telephone system. Each time you press a 9 for a line the system simulates a dialtone to see what your dialing next so it can check it against the automatic route selection table. After it checks, it pulls a line out of a pool group to complete the call. At this point its grabbing a line that is not working on the system.The best way to figure out which ones arent working is to check the lines on the main console by pressing each line button and seeing if it produces dialtone. More than likely(but not allways) its going to be a line problem from your dialtone provider.
Sep 21, 2010 | Lucent Merlin Legend MLX-10D Phone
I can't recieve faxes with my HP Laserjet 3015
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 18, 2010 | Office Equipment & Supplies
No dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
My house phone is not working
Unplug all phones in your house- all of them. Wait 5 minutes then plug a phone in a try it again. You probably have TIP n Ring reversed ( Red and Green wires) or your hookswitch on the phone is bad. If you do get dialtone after you wait 5 minutes and can hang up and get dialtone back get a new jack and try that ok
Nov 13, 2008 | Motorola Lands Phones
Dialtone
http://www.retrevo.com/samples/GE-manuals.html
follow the link above and also try to get an earlier or newer moddel manual ;) take care
Oct 22, 2008 | Uniden Cordless Phone
RCA 25423RE1 Phone Logo
175 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
