Question about Amana Plumbing
Pump goes on and off too often - Amana Plumbing
  • Joel Friedenberg May 11, 2010
    What type of pump? what is it connected to? Submersible pump, sump pump, booster pump? Explain the hookup please.
  • 4 Answers
Your pump is overheating. Check the current draw of your pump during operation. The amperage should not go above its current rating.
Remember Power (Watts)= Voltage (VAC) x Current (Amps). For a 100 Watt motor running at 120 VAC then the current I should see is approximately, 1.2 Amps. If I see 2 amps draw on the motor then I now its about to burn up or another problem has occurred. Values higher then 1.5 times the nominal operating current shows problems with motor or motor operation (excessive load, bad bearings, exc.)
Make sure that the pump is fully primed during entire operation. Note: Pumps hate cavitation and dry run times!
If all of the above is ok, then you may need to increase the capacity of your pump or place two of the same pumps in series for the extra head pressure.
Posted on Aug 04, 2009
How do i set up the hoses on the BHR170 pump?
front of pump goes to skimmers and main drain if inground pool skimmer if above ground top goes to inlet of filter then outlet of filter goes to pool returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
Wayne WAPC250 1/4 Auto On/Off Pool Cover Water Removal Pump
good pump its a rule by the way a lot of times the automatic goes bad cause the hoses frezes and the pump goes bad
Apr 07, 2013 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Which side is the inlet side filter or pump?
Water goes into the center inlet of the pump first. Then it exits the pump from the side outlet and goes into the backwash valve. From there, it goes either into the filter, backwash, drain or waste depending how the valve is set.
Gary
Jul 17, 2011 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
I have forgotten what hose connects to what from pool to pump. above ground simple pool pump.
Discharge of pump goes into inlet of filter, outlet of filter goes back to pool.
Line from pool skimmer or bottom goes into inlet of pump.
Dec 21, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
How do I hook the pool to the filter and then to the pump
The outlet from the skimmer on the pool goes to the pump inlet (center part of the pump). The pump outlet goes to the filter inlet. The filter outlet goes to the return to the pool.
Jul 04, 2010 | Hayward Pro Series 18" Above Ground Pool...
Which tube takes water from pool to pump and which tube puts water back in on the model 633
The outlet from the skimmer goes to the pump inlet (center) the pump outlet goes to the filter inlet. The filter inlet goes to the return to the pool.
Jul 03, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Which hose goes where when hooking the pump up to the pool?
The outlet from the skimmer goes to the pump inlet the pump outlet goes to the filter inlet the filter outlet returns to the pool
Jun 19, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Need diagrams of 4 belt system 1987 chevy 350
back belt nearest the engine goes around the crankshaft pulley and the power steering pump
next belt out goes around crankshaft, power steering pump water pump and ac compressor
next belt goes around crankshaft water pump and alternator
last belt goes from water pump to smog pump
Feb 21, 2010 | 1987 Chevrolet R10
Intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Jun 16, 2009 | Intex 4000 GPH Filter Pump
'98 sonoma fuel pump,which line goes where in the pump?
the line that feeds fuel filter is the 1 that connects to pump,other line is the return!
Mar 16, 2009 | 1998 GMC Sonoma
Plumbing Logo
102 people viewed this question
Top Amana Plumbing Experts
Donni Steen
Tom Chichester
Are you an Amana Plumbing Expert? Answer questions, earn points and help others
