Question about HP Asus Motherboard P4SD-LA Socket 478 DQ182-69002 5187-6671
P4sd socket 478 motherboard is not booting up at all !!!
Hi
I have p4sd socket 478 motherboard and its not booting up at all.
Actually nothing is happning. I removed all power supply from SMPS and plug it on again, removed RAM and plug it again, Removed HDD and CD drive and try to make it ON but nothing happned...
I can only see one LED which is blinking and its on mother board exactly down side on BIOS reset button. when i pluged power cable, after pluged power supply, couple of times i did try to make on using power on button but nothing happned.
What i got to know non of the fan (SMPS) , CPU and exost one are not running at all.
Please, help me to diagnose this problm and how can i solve it.
Thank you for your kind help in advance.
Sam
  • vpanchasara Aug 05, 2009
    Hi Dil
    As you mentationed, I replace SMPS with old one and removed all the periferals and used the new poswer supply. After using the new power supply still CPU fan and power supply fad didnt started and nothing happned. As you thought mother board burnt, for this i removed mother board from cabinated and checked if i can see anything like burnt on mother board itself, but i didnt found any visual demage which can say me its burnt.
    Do you think mother board is burnt ?
    if mother board dont have any problem then what can be ... ?
    Thank you so much for your reply.
    Sam
  • vpanchasara Aug 11, 2009
    Hi Dileep
    As you mentationed i removed all connection and only connected motherboard and power suppy. When i press power button on box, i can only see bleeking led on mother board noting els happned. SMPS fan and CPU fan didnt started or not ran. Even i changed power supply with the same one but still its not working same response. what i did i just continuously press power button, then same way CPU cabinate front led (power indication LED blinking in the same way mother board one).
    Please let me know what you think about the problem.
    I even checked surfacly, i can't see anything on mother board which says me mother board is burnt from this place !!
    Sam
  • 20 Answers
1st check if the voltage from the plug has correct groung , neutral phase set .then
try a new smps , with minimum 400W output.
before connecting the same.
please remove all the parts out of the cabinet please connect only motherboard and smps and check its getting switched on , if not then your board is burnt you will have to replace it , if there is power indication then connect the RAM and check , if its also fine then connect the rest and try.
all this u have tried and no use , please post me a msg with full detail of your PC configuration , I can try a resolution
dil.
Posted on Aug 02, 2009
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Motherboard has nothing connected to it. i need to know where to connect the cables for the whole computer
connect poer supply to motherboard socket which is near processor beside and see light will bleep on motherboard
Oct 22, 2010 | HP Asus Motherboard P4SD-LA Socket 478...
ASUS P4SD i865G Socket 478 mATX Motherboard
if i was you i would atleast get windows xp manyour board is more new then your win 2000 but go online you can find them there just type in google your board type
Mar 30, 2010 | HP Asus Motherboard P4SD-LA Socket 478...
My pc has no sound
Download motherboard sound drivers from the motherboard manufacturer. The bios has nothing to do with your sound drivers in your operating sytem.
Cheers.
Please rate!
Sep 28, 2009 | HP Asus Motherboard P4SD-LA Socket 478...
Replacement for INTEL Desktop board D865GLC
I've found an Asus P4SD i865GV online:
http://www.geeks.com/details.asp?invtid=ASUS-P4SD-NOAGP-R&cat=MBB
It seems to have the same CPU socket, FSB and RAM types, and the chipset is almost the same model. I'd say this would work.
If you can't get that, just make sure to get a motherboard with the following qualities:
Front side bus (FSB): 800, 533, and 400 MHz
RAM type: Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
CPU socket: 478
Aug 07, 2009 | Intel Desktop Board D845BGL Motherboard
HP Asus Motherboard P4SD-LA Socket 478 DQ182-69002 5187-6671 Logo
618 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
