Question about Tascam US-1641 Sound Card
Clicking noise when recording bass directly into 1641 to Sonar studio 7Running ASIO 4all drivers Vista with quad 1.8's, 3 Gigs ram
  • 22 Answers
Is it just clicking noise or is it skipping. check out and tell me
one more thing , can u specify what mother board you are using.
Contact me immediately
greatvedas@gmail.com
Posted on Sep 08, 2009
Audible click/pop when starting program. ASIO
Due to the DIGI001 ASIO settings, the HALion engine and program should be used as a plug-in (VSTi) in your master DAW, (i.e., Sonar, ProTools, Cubase, etc.) and it should fix the problem. Ensure that your drivers are updated and direct all signal traffic to the input device that is shared throughout your system or simply reassign your "patchwork" through the main DAW as mentioned above.
Peace
DJDIRTYDISHEZ
Oct 12, 2009 | Steinberg HALion 3 Full Version for PC,...
Sound stops for no apparent reason. Don't know which to use in Sonar ASIO MME etc. Dan
Many factors determine the efficient processing of digital audio. Just a few things that I discovered that are involved.
How much RAM does your machine have?
Are other processes operating in the background?(eliminate any un-necessary operating system processes) Caution is the watch word here and you might want to hire someone who has done it or consult with an audio engineer.
MME drivers are not the best choice.
ASIO is best with sonar but do you have the latest drivers installed?
Are you using a machine that has USB 2.0 ports installed?(USB 1.0 won't cut it)
Is there a second storage drive separate for audio(highly suggested)?
How many tracks are you trying to playback or record?( related to drive and ram speeds)
Are you recording at 24 bit or 16 bit. Might try 16 and see if this helps.
Is the cache enabled?
Are you using a lot of plug-ins like reverb and soft syths. These require a lot of on board memory and good speed.
All in all I always suggest a machine dedicated, optimized and setup for audio use only if you want to save many hours of frustration and to produce high quality audio.
Lots of Ram/Large dedicated fast hard drive/All processes optimized by eliminating things you don't need or can live without in the operating experience. Also if you are using a Window machine you can sign up at musicxp.net and get the instructions on how to optimize your machine for audio.
I hope this helps solve your problem
Oct 11, 2009 | Tascam US-144 Sound Card
Computer stops responding or sound just stops on Sonar 7 with Vista. Confused whether to set Sonar to use ASIO driver or MME or the other one I can't think of now. Dan
Hi
The most compatible driver would be the one detected by Vista in Windows Update. Give that a try and see if it can find a hardware device driver for the Sonar. Ensure the Sonar is connected and on before you check for updates (Start > All Programs > Windows/Microsoft Update).
WDM or ASIO drivers in LynxOne?
Go with ASIO for reduced latency. Preferably the ASIO driver available for your card at the LynxStudio.com web site.
Mar 16, 2009 | lynx studio LynxONE Sound Card
Says ive used all my memory up but i havent
Armada M700 Specs
Full sytem requirements of FL Studio:
  • Pentium III or Athlon XP (any processor supporting SSE instructions) or Intel Mac with Bootcamp (running XP or Vista) or running Parallels
  • Windows 2000/XP/2003/Vista (32 & 64 bit)
  • 256MB ram
  • 200MB free harddisk space
  • Windows-compatible soundcard with DirectSound drivers. ASIO drivers are required for audio recording (FL installer comes with generic Asio4All drivers)
If your system meets the minimum system requirements, it'll be your actual system resources (memory, CPU, ...) that could impose limits on your FL Studio projects.
The faster your CPU the more channels you will be able to run simultaneously and/or the more effects you will be able to use. The more memory you have the larger the samples you will be able to load.
May 15, 2008 | Compaq Armada M700 Notebook
PLaying and Recording
Look in your MIDI instruments and make sure the icon for you to play back is lit.
Apr 20, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
Recordin audio problems (drop out)
cheak msconfig start ups eating ram that needs alot ram be nice to add 1 gb more run cc cleaner.com tool get junk out update your software form webite fl latest flash adobe shockwave and java run spyware clean up close out all other programs when u work in studio program
Mar 17, 2008 | Edirol UA-4FX External Sound System
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Tascam US-1641 Sound Card Logo
197 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
