Question about Coby DVD-224 DVD Player
Coby dvd 514: My dvd tray won't close. I've taken the top of the unit off and instead of the tray sliding between the top magnet and the bottom, it slides under the bottom spindle.
  • 158 Answers
TAKE IT TO A TECH FOR ALIGNMENT
Posted on Aug 03, 2009
SE PUEDE USAR UN CONTROL REMOTO COBY 514 EN UN DVD COBY 224
Quisas. Only if the control frequencies for both units are identical. Since you are dealing with same manufacturer you have a better chance of it working than if you were using two units from different manufacturers.
Mar 21, 2015 | Coby DVD-224 DVD Player
My Coby DVD-514 will not open. The display reads 'open' but the drive does not open to insert a DVD
you have to unplug the dvd player open it up then remove the face, it should have two screws on each side.after you have done that look under the dc draw you will see a gear spin it counter clock wise then the tray will come out.when it reach aout half way lok inside wher the try was ther should be a belt replace. if it looks ok just pull the tray all the way out and back in shoud set it good luck
Aug 01, 2010 | Coby DVD-514 DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
Coby 514 change region solution
Try these two. they seem like they'll work. Their both for this unit.
Turn unit on with remote
NO DVD in the tray closed or opened might work
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
1. Open the DVD tray
2. Press 'STOP' button on the remote control
3. Press '70'
4. Press 'MENU PBC'
5. Use the numeric keypad to select your region code number (0 – 6). 0 is all regions.
6. Press 'Enter'
Oct 11, 2008 | Coby DVD-514 DVD Player
Error messages
open the dvd player check and see if the lens is lighting bright red when u close the tray(do not watch directly at the lens) if it is not lighting the flex cable is bad.now if it lighting and the cd spins slow change the motor. (clean lens first)
Jul 12, 2008 | Coby DVD-514 DVD Player
Coby dvd 514 remote
BAD NEWS.....I READ THIS FROM THE COBY PRODUCTS WEBSITE: COBYUSA.COM..... What is the code to program my Universal remote with my Coby DVD player? There is no code to program our DVD players with your Universal remote, you need to use the remote that came with the player.
Aug 27, 2007 | Coby DVD-514 DVD Player
Region setting
COBY DVD-514
power on, open disk tray (leave open, closed with no disk in might work too, didn't try), with remote press SETUP, them VOL+ VOL- VOL+ VOL-. On the top right side of the screen your region code will appear, use the left and right nav keys on the remote to switch between regions, and 255 (there is no 0) for all regions
Jun 12, 2007 | Coby DVD-514 DVD Player
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
NO DVD in the tray (mine was closed, but opened might work)
Can not open the dvd tray
My DVD Drawer was stuck to.
Thanks; I hit both the top and bottom of the DVD player and lo and behold the drawer popped right open!
Jan 22, 2007 | Gateway AR-230 DVD Recorder
Coby DVD-224 DVD Player Logo
105 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
