Question about Maytag M6Y18F7A Air Conditioner
The AC runs on high only low or med and the ac shuts down. What part do I need?
    Guru:
  • 588 Answers
Check to see if your getting the proper voltage to medium and low speed at the switch, if you are then the switch is good and you have an open winding in the motor and it needs replaced to correct the problem, if not then you need to replace the switch.
Posted on Aug 10, 2009
  • 1 more comment
  • Bill Long Aug 10, 2009
Ac/heater will only work on low when you move it to med or high it shuts off
need to check switch,resistor and fan ---ur switch might have resistor built in it would need to be tested for continuity for the other speeds --if your truck [didnt specify which ] has a separate resistor it should be attached to the heater fan motor housing again resistor needs to be tested -also test ur fan for any resistance or overheating
Apr 10, 2014 | 1993 Toyota Pickup
Ac/heater onlu works on low
you either have a bad switch or bad fan motor. I would start by replacing the switch
Apr 09, 2014 | 1990 Toyota Corolla
2008 Honda Odyssey AC fan works on low and med speeds but no high speed blower
There should be a high speed blower relay that bypasses the resistor for slower speeds.
Check with an auto parts store or the dealer.
Jun 23, 2012 | 2008 Honda Odyssey EX-L
Ac fan will not run on high setting , manual or auto . when unit calls for high setting fan shuts down . Compressor continues to run and trips breaker in trailer . Someone thinks it may be the motor, but...
Most probably its weak motor.When the motor gets weak it trips/ stops on high setting.On high setting motor needs more power to run the fan.Try lubricate the motor .You may need a few drops of oil on the fan motor bearings. As they get older they get dry and gunked up. If you can see the bearings a few drops of oil may help. --------- Because the fan operates on medium and high, so loose wire or faulty fan switch is very rare to cause this problem.-------- As per the problem , it requires motor to be replaced.--------- This will help.Thanks.Helpmech.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
91 chevy Siverado 2500 AC Blower problems
My guess would be the same as yours. Good job.
Jun 23, 2010 | 1991 Chevrolet Silverado 2500
Rear AC fan will not run in lo med or hi, switch or is there resistors on the fan that need checked?
When a blower motor does not turn on in low or med. and only turns on high its usally a resistor block. If nothing works it is most likely the bolwer motor itself or a fuse.
Feb 28, 2010 | 2001 Chevrolet Suburban
Ac fan will not work on low or med only on
It may well be the fan switch is defective
Jul 27, 2009 | Heating & Cooling
Coleman outdoor furnace/AC blower speed too fast
You are right slow for heat and fast for A/C. Here are the blower speeds black is high blue is med. and red is low if you have orange it would be med low. Look on the control board and see what color wire is connected to heat and let me know if you have something other then control board. You can take the wire that is on park and swap them around. ken
Jan 11, 2009 | Heating & Cooling
Maytag M6Y18F7A Air Conditioner Logo
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
