Question about Philips 13MDTD20 13 in. TV/DVD Combo
Phillips 14pt6107s/05 think kids have played about with tv controls,everything fine but no sound??? tried all the menu options but no joy,what is the music note on the green button for and how do i use it
  • Kashmira Singh
    Kashmira Singh Dec 08, 2007
    i can't find an instalation menu in english all the menu's are in forgine.
  • bigos Oct 05, 2008
    when i was retuning my tv sone one switched it off now the only sound i get from the tv chanels is white noise the sound from the dvd is fine can you help me?
After replacing microprocesser ST92T195D7B1 all the menu's are ok including english menu .But their is no sound through tv channels. when playing dvd the sound is ok.so i still need some help.
kind regards kingkash
Posted on Dec 12, 2007
Tv shows no picture or sound or menu options
replace power supply or inverter board (note)some power supplies have inverter circuits intergrated on the power supply circuit
Jan 21, 2013 | Element Electronics Televison & Video
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
No signal from xbox to tv
Try resetting resolution and then tweakin sound setting in menu.
Look Here: http://cocaman.ch/wp/2006/12/reset-xbox360-resolution/
Jan 10, 2009 | Microsoft Xbox 360 Console
I am tryin to connect my Phillips HTS3011/05 home cinema system to my Technika LCD32-207 tv. It works fine if i watch a dvd, but it doesnt work when i play my Xbox 360 through its HD cable, or watch normal...
My TV has a Output port, It is only output for sound, IF you TV has this, then you need to use those, But i dono if it would have them, If it dosent the you will not be able to use the surround for everything without Plugging it in as you use it,
Nov 25, 2008 | Televison & Video
No sound, No more
Sorry it took so long to reply, to your request for help. You need to use you owners manual and go to the section on audio controls. Check every function that can turn off the volume to the television while it is playing. Make sure all the controls are set properly for the use of the audio on the television. If you cannot find the problem and correct it this way, you can call the RCA customer support telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for their assistance. I hope this information helps you with your remote control problem. Thank you for using FixYa and have a nice day!
Oct 26, 2008 | RCA DIRECTV Satellite Remote Control
Picture Blown Up
Hello jasalf,
This problem is called blooming, and it is caused by poor High Voltage Regulation. It usually denotes a problem in the HV section of the TV. More then likely the problem is in the IHVT (Integrated High Voltage Transformer).
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Aug 21, 2008 | Proscan PS27123 TV
Phillips 14PT6107S/05
I found this on the net:
Try this, there are 2 versions of this set, one of these will work.
14PT6107
ENTER 062596 ON REMOTE
WITHIN 5 SECS PRESS MENU
SERVICE MENU SHOULD APPEAR
SELECT DVD
PRESS ENTER
OPTION 1 USE RIGHT BUTTON TO SELECT REGION "ALL"
NOW PRESS MENU 3 TIMES TO EXIT
OPTION 2 TYPE 00 PRESS OK
THEN MENU THREE TIMES
GO IN TO STANDBY AND POWER BACK UP
Option 2 worked for me. The thing I was failing to do was going in and out of 'standby'.
Also there is no 'all' instead 00 = 'all'
Jun 12, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Yamaha DVX-S120 On Screen Menu - Phillips brand
The same happened to me! DVD's play fine but on screen menu just changed and Video Output option is gone! Also de Philips logo on screen which I suspect is placed there by my TV (which is a Philips one) and as it does no longer receive the background screen from the DVX it just puts its own. Is your TV Philips like mine?
Mar 26, 2007 | Yamaha DVX-S120 System
Philips 13MDTD20 13 in. TV/DVD Combo Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
