Question about Samsung HT-WX70 Theater System
We have done the reset several times and still can't get the rear speakers working. Do the sound cards on the back go bad?
  • 158 Answers
SWITCH PROLOGIC MODE ON IN AUDIO SETUP
Posted on Aug 03, 2009
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Tip
Why is there no sound coming from my speakers?
If you hear no sound coming from your speakers, there could be several reasons:<br />1) Check to see if the speakers are powered on.<br />2) Check to see if the cable is plugged into the speakers and the green jack in the back of the computer.<br />3) Check to see if the speakers are muted in Windows. Do this by clicking on the speaker icon in the system tray. It has a place to check to mute the speakers.<br />4) Check to see if the sound devices and drivers are loaded. To do this go to the control panel and click on "sound." Then click on the sound tab. Choose one of the Windows events that has a sound associated with it and preview the sound by clicking on the arrow to the right of the listing. If the arrow is dark and when you click on it the sound seems to be playing, then the drivers and sound card should be functional. If the arrow is grayed out, then your sound drivers are not installed. In either case, try reinstalling the sound drivers.<br />5) If you've tried all this to no avail, try with another set of speakers.<br />6) One thing that may work is to do a system restore back to the time the speakers were working.<br />7) If nothing works, I would suspect that you have a bad sound card. Unfortunately, these days sound is integrated into the motherboard, but you could install an add-on sound card.<br />
on Apr 18, 2011 | Computers & Internet
Creative SB X-Fi titanium rear speaker out problem
Hello.
This sound card it is well compatible and all you have to do its depending on your OS update and reset the sound properties to get the full reestored sounds of all channels.
Hope this hint helps
Carl
Apr 02, 2017 | Creative Technology Creative Labs Sb0880...
My gigaware external speakers appear to be not working anymore. I tired restarting my computer several times and plugged in the speakers several times and nothing is helping
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question or exclamation mark ! ? or red x right click to re-install drivers
hope this helps
Jul 29, 2011 | Computers & Internet
The system worked fine but has an intermittent connection in the main power tower unit..you can shake the unit or bump it heavily and the sound from the main tower speakers goes and comes with a lot of...
They are prone to bad solder connections on the power regulators and output ics. should only be a labor charge. est $60 -100
Not very easy to take apart, need to remove several screws on rear of unit, remove front grill remove some screws on front. disconect connectors remove amp and power supply board, resolder bad connections and re-assemble. I've done several would take me 30-45 min.
Nov 12, 2009 | Sony SA-VA1 Rear Speaker
Sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 20, 2008 | Logitech Z-5500 Computer Speakers
Rear Speakers do not sound, other 2 do, and boofer.
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
7949.jpgGreen connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
IrishDruid
May 04, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Speakers System
7949.jpg Green connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
Hope that helps!
IrishDruid
Creative X-Fi Xtreme Gamer XP SP2 drivers
what the hell are you talking about, the card isn't "vista only"
Jan 25, 2008 | Creative Labs Sound Blaster X-Fi...
Have no sound on front and rear speakers...
looking at the front of the unit take the left side pannel and replace the fuses. ive had to do that with mine several times because of the same problem
Sep 10, 2006 | Sharp CD-C460 Shelf System
Samsung HT-WX70 Theater System Logo
246 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
