Can a samsung home theater system work with a emerson 32" Digital/analog LCD tv
    Problem Solver:
  • 15 Answers
Yes
Posted on Aug 03, 2009
How do I hook up my HDMI Blu ray player to my theater system that doesnt have HDMI
You have a few options depending on the entire system.
Do you have the TV audio output connected to the home theater system? In that case, connect the Blu-ray player to an HDMI input on the TV. Then leave the home theater system set to the TV input, while the TV is set to the HDMI input for the Blu-ray player. This is the simplest method.
You could use an audio extractor/converter. Here's an example: https://www.amazon.com/J-Tech-Digital-Premium-Extractor-Converter/dp/B00BIQER0E . This will let you send the video signal to the TV (with a second HDMI cable) and have digital or analog audio sent to the home theater system.
If the TV doesn't have an available HDMI port and the home theater system only has analog audio inputs, you could use an HDMI to component video converter. You'd use something like this: https://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html . (Do not use an HDMI to component cable. Those only work with some projectors.)
I hope this helps. Please add a comment with more details about your TV and audio system for more specific information.
Feb 14, 2017 | Samsung Audio Players & Recorders
I want to upgrade to a 4k tv but my home theater does not support 4k. Can i run sound only thru it?
You can run the sound to the home theater system in many cases. It depends on the home theater system and the TV. If the home theater system has a digital audio input, it is easy to connect most 4K TVs. Connect the 4K source to the HDMI or Displayport connector on the TV. Check whether the digital audio uses an optical cable or a coaxial cable. Make sure that the TV has the matching output and get the correct cable. Set the TV to use external speakers (under the Audio part of the setup on most TVs) and turn off the internal speakers.
Very few 4K TVs have analog audio output. If your home theater system only has HDMI and analog (RCA red/white) audio inputs, you will need a digital to analog audio converter and both digital and analog audio cables. The converter will look like this: https://www.amazon.com/Gefen-Digital-Adapter-Converter-GTV-DIGAUD-2-AAUD/dp/B0013LWK3A .
I hope this helps. Please add a comment with the make and model of your home theater system if you need a more specific set of details about doing this.
Nov 20, 2016 | home Audio Players & Recorders
How to fix a kef kit 100 home cinema so sound can go through the kef instated of tv. I have samsung ue55f6800 tv
Just go into the menu of your Samsung TV and in the set up you will find an element "sound" put it on external Hi-Fi System and it Will send the sound to your Home Theater system, Witherspoon via analog or via digital(optical) cable.
Jun 07, 2014 | Audio Players & Recorders
Dark lines running vertically in lcd tv
is problem when u are play with dvd or normal analog signal or digital sinal which one specify if in all your lcd some hardware problem
May 19, 2012 | Sony Bravia L-series Kdl-32l5000 32-inch...
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
How to connect samsung dvd surround to my tv to get sound
if your tv has a digital out jack and your samsung has digital in jack use an optical cable. if your tv have analog jacks (Red and White) use audio out from tv to audio in on samsung surround, labeled video1,2 or aux
Oct 21, 2009 | Samsung HT-Z310T Theater System
HOW DO I CONNECT MY DVD THEATER SYSTEM TO MY FLAT PANEL TV?
just either use rca jacks from the dvd to the tv,,u know ..the red,yellow,and white cables,,,,that will do it,,,using the rca jacks ,,make sure to set the the dvd/reciever settings to anolog
May 17, 2009 | Durabrand Televison & Video
No off/on for TV (Emerson) Was working.But no more
call the funai corp. they can help you with all your questions
Nov 29, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
